B18c crx hood shutting problems. Any tricks to fix?
Old Apr 29, 2003 | 08:23 AM
HT Chaplain's Avatar
Loved
Default B18c crx hood shutting problems. Any tricks to fix?
I just put a b18c in my crx with hasport mounts. The hood doesnt shut without bowing up the drivers side. When I pop the hood i have to pull it up and the lever is very hard to pull out. Is there any tricks to fix the problem? Has anybody else had this problem?
Old Apr 29, 2003 | 08:36 AM
Newman's Avatar
New User
Default Re: B18c crx hood shutting problems. Any tricks to fix? (legutki)
Your problem are the mounts. Not saying that HASport mounts aren't good, but they place the motor higher, allowing for more clearance for the pulley with the radius rod. With the HCP kit, it sits slightly lower, and more towards the firewall (allowing for straight axle alignment) and will allow a B18C to clear the hood, but requires you to use a 90-91 Integra pulley, which is smaller. It's a compromise.
Old Apr 29, 2003 | 09:26 AM
HybriDNA's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by legutki &raquo;</TD></TR><TR><TD CLASS="quote">I pop the hood i have to pull it up and the lever is very hard to pull out. Is there any tricks to fix the problem? Has anybody else had this problem? </TD></TR></TABLE>
You can try and spin the rubber mounts that are on the corner of the hood and spin the latch pin on the hood counter clock wise so that the latch won't be to hard to release. At least this is what i did. It works.
Also you can get a dremel tool and cut out the inside of the hood so that it can clear top of motor.
Old Apr 29, 2003 | 10:20 AM
Loved
Default Re: B18c crx hood shutting problems. Any tricks to fix? (HybriDNA)
Good idea Ill try that thanks Hybriddna
Old Apr 29, 2003 | 10:22 AM
HybriDNA's Avatar
No problem.. just trying to help out a fellow h-t memeber.
hondatuner020
11
Mar 27, 2015 04:35 AM
SuperSteve737
Dec 4, 2003 11:44 AM
Hites
13
Nov 15, 2003 12:10 PM
Outkast_CL9
15
Sep 20, 2003 11:13 AM
hurleyburley
Feb 18, 2003 11:15 AM
