to do list for b18b into 96 dx hatch
Old Apr 28, 2003 | 11:15 PM
GRAVEDIGGER's Avatar
Default to do list for b18b into 96 dx hatch
what mounts ,i take it i use integra axles,shift linkage,96-98 ls ecu. what else is there? any wires that need to be extended besides hard wiring in a 4 wire o2. what else to make this swap a breeze?Thanks
Old Apr 29, 2003 | 12:02 AM
moike's Avatar
you will need an a/c bracket from a B-series del sol if you want to keep your A/C. also you need a rear mount from an integra and a driver's side integra mount i believe.
don't forget the intermediate shaft too when you're looking for axles.
Old Apr 29, 2003 | 07:19 AM
ransack's Avatar
Default Re: (moike)
Allright.
99-00 Si Rear Mount ("T" looking one)
99-00 Si Driver side mount (One that mounts TO the engine)
96-97 Civic Ex 5speed Wiring Harness
Wiring Harness that came with Swap (I think you need it)
Integra Axles
Del Sol Raditor Hoses
LS Ecu
LS Throttle Cable
Buy plenty of Oil, Filters, LOTS of hose clamps, wiring tools.
I think theres might be more. IF you need more info, IM me.
Old Apr 29, 2003 | 08:59 AM
Trey's Avatar
25 Year Member
Default Re: (ransack)
You don't need an EX harness with an LS swap. No Vtec. But the wires are easier to route. If you use the DX harness, you'll need to cut and extend quite a few wires. Not hard though if you know what you are doing.
EK Swap guide in my sig below too.
Old Apr 29, 2003 | 10:13 AM
ransack's Avatar
Default Re: (Trey)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Trey &raquo;</TD></TR><TR><TD CLASS="quote">You don't need an EX harness with an LS swap. No Vtec. But the wires are easier to route. If you use the DX harness, you'll need to cut and extend quite a few wires. Not hard though if you know what you are doing.
EK Swap guide in my sig below too. </TD></TR></TABLE>
yeah you don't need it. but its easy to wire up. Plus if you go VTEC in the future, your ready.
Supahatch
Nov 15, 2005 10:11 AM
fasterthenmost
Oct 14, 2005 07:57 PM
J-Spec EG
Dec 20, 2004 08:17 AM
aznphantoms
Nov 14, 2004 04:37 AM
Midwestrider
Nov 11, 2004 02:24 PM
