Del sol shift linkage on 93 CX?
Old Apr 28, 2003 | 12:20 PM
P1mpSlap's Avatar
Default Del sol shift linkage on 93 CX?
Will the VTEC Del Sol's shift linkage be able to work with the GSR's shifter stabilizer going into the 93 Civic CX?
Need to know ASAP.
Old Apr 28, 2003 | 12:31 PM
P1mpSlap's Avatar
bump anyone?
Old Apr 28, 2003 | 01:01 PM
P1mpSlap's Avatar
I guess no one knows the answer to this....
Old Apr 28, 2003 | 01:05 PM
DenMatic's Avatar
Default Re: Del sol shift linkage on 93 CX? (P1mpSlap)
no. the delsol shift linkage is a bit longer and bends up and wont work with the stabilizer bar. any b-series shift linkage and stabilizer bar from a DC integra will work.
Old Apr 28, 2003 | 01:10 PM
P1mpSlap's Avatar
This is a B series shift linkage, just off a Del sol.
You think it still wont work?
Old Apr 28, 2003 | 01:52 PM
P1mpSlap's Avatar
anyone?
Old Apr 28, 2003 | 03:27 PM
DenMatic's Avatar
Default Re: (P1mpSlap)
if you put a del sol b-series shift linkage along side a b-series integra, they are different. it will not work. the del sol has a bend that helps the shifter reach the cabin inside the car. in a delsol, the shifter is closer to the steering wheel than a teg or a civic. i own a del sol. they are both different. if you want to cut/weld/straighten out the del sol linkage, thats another story.
Old Apr 28, 2003 | 06:56 PM
92b16vx's Avatar
Delsol shiftlinkage (B series and D series) is different shape and length as Denmatic said,it doesn't work on a civic,you need linkage from a teg or civic based B series.
gmcuajo1
Transmission & Drivetrain
Jun 4, 2015 04:02 AM
gmcuajo1
Jun 1, 2015 08:03 PM
redline870
Mar 23, 2011 09:30 AM
gsrpedro
Aug 20, 2008 11:23 PM
jaydmej1
May 20, 2004 08:30 AM
