Maybe you tech people know. LS/Vtec ???'s
Old Apr 28, 2003 | 09:40 AM
B18C1 '96 Coupe's Avatar
Default Maybe you tech people know. LS/Vtec ???'s
No one knows in Hybrid. What do you guys think
Ok search reveals some info and Junk. I need to know what what setup will pull
Im thinking of going LS vtec but was wondering what the best setup was.
1. B18B Block, ITR pistons, B16 Head, CTR Intake cam and ITR Exhaust cam, Skunk2 Titanium retainers, ITR Intake valves and valve springs and GSR Exhaust valves and valve springs, LS rods and B16 crank.
2. B18B Block CTR pistons, B16 Head, CTR Intake cam and ITR Exhaust cam, Skunk2 Titanium retainers, ITR Intake valves and valve springs and GSR Exhaust valves and valve springs, GSR crank, LS rods.
3. B18B Block CTR/ITR pistons, B16 Head, CTR Intake cam and ITR Exhaust cam, Skunk2 Titanium retainers, ITR Intake valves and valve springs and GSR Exhaust valves and valve springs LS rods and LS crank.
Would these two setup fall flat on thier *** on top. Or would the GSR crank allow The revs and nice top end?
What would be say the 'ideal' setup?
This is what ive gotten from somewhat of my reasearch. Let me know thanks.
Old Apr 28, 2003 | 10:17 AM
delslow94's Avatar
Default Re: Maybe you tech people know. LS/Vtec ???'s (B18C1 '96 Coupe)
if u use the gsr crank ur just building a gsr motor. thats the whole thing that separate the lsvtec and gsr. the ls crank has around 1.5mm larger stroke which gives it more torque. i say use the eagle rods and ls crank or as u have it listed number 3
Old Apr 28, 2003 | 12:27 PM
CHEETAH's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18C1 '96 Coupe &raquo;</TD></TR><TR><TD CLASS="quote">
choose this one with a JDM 4-1 header and a custom GBR Tuning.com ecu and you're setup ... 200hp or bust
greg
Old Apr 28, 2003 | 01:32 PM
Default Re: Maybe you tech people know. LS/Vtec ???'s (CHEETAH)
even though its running the GS-R crank? I like 200+ hp out of the box. MMMM.
Old Apr 28, 2003 | 01:36 PM
MikeMAN's Avatar
hey cheetah, ur missing one "w" in the top link in your sig
mike
Old Apr 28, 2003 | 02:33 PM
sander's Avatar
2.7(p/t)
Default Re: Maybe you tech people know. LS/Vtec ???'s (MikeMAN)
i have lsvtec, and if i werre you and were driving this every day i would go with a b16 piston (pr3 or p30), they have a higher dome than the ITR piston and smaller than the CTR. they should put around 11.3-11.6:1. but every thing else looks good.
Note: if you think you can tune the car to run around 12.3:1 with a CTR piston, then go for it, but a safe bet is just an everyday b16 piston.
Old Apr 28, 2003 | 05:04 PM
dfoxengr's Avatar
Default Re: Maybe you tech people know. LS/Vtec ???'s (delslow94)
u can only use a b20b/z or LS crank to make an LSvtec...
Old Apr 28, 2003 | 05:16 PM
fukaintmuven's Avatar
Default Re: Maybe you tech people know. LS/Vtec ???'s (hybridvteceg)
if possible go with a 94-95 b18b block becasue it already comes with a pcv valve? or that crankshaft ventilator... ctr pistons are easy run on 92-93 octane. tunning is the key on ls/vtecs
hey greg im from new brunswick... how much could u make me a *special* ecu to run my ls/vtec 13-0 cr with ctr cams and 310 injectors
dingusjt
Sep 18, 2004 05:54 PM
Spids5
May 1, 2003 04:38 PM
B18C1 '96 Coupe
Apr 28, 2003 02:15 PM
rondigs
Jan 24, 2002 07:46 PM
