strange behavior with brakes @ expo
odd thing happened to me at the expo....i swap brake pads...and as soon as i go off to the waiting paddock to pick up yasu my brakes stop working. The brake pedal goes right into the floorboard without pressure.
after pulling back into the my waiting area the brakes start working again, automagically. i check the fluid, everything seems normal.
can anyone explain this? i'm still baffled to this day.
.after pulling back into the my waiting area the brakes start working again, automagically. i check the fluid, everything seems normal.
Perhaps the piston wasnt "settled" against the rotor yet. When i push the piston back in when swapping pads and then go to brake for the first time,foot goes to floor for one or two pushes...
you need to pump the pedal a few times. always do this when changing pads so you dont fly off onto the road leaving your parking lot (not that i've done that)
a full stroke of the pedal (heh, he said stroke) doesnt correspond to full stroke (heh, he said it again) of the caliper piston.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rguy »</TD></TR><TR><TD CLASS="quote">Perhaps the piston wasnt "settled" against the rotor yet. When i push the piston back in when swapping pads and then go to brake for the first time,foot goes to floor for one or two pushes...</TD></TR></TABLE>
I agree
I agree
I forgot more about hondas then you will ever know....
From: hop,skip, and a jump from the city,, new friggin york, USA
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Soup **** »</TD></TR><TR><TD CLASS="quote">
can anyone explain this? i'm still baffled to this day.</TD></TR></TABLE>
probably an excess buildup of dirt (from offroading) on the brakes..... j/k bro, what they said.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .RJ »</TD></TR><TR><TD CLASS="quote">you need to pump the pedal a few times. always do this when changing pads so you dont fly off onto the road leaving your parking lot (not that i've done that)</TD></TR></TABLE>
Ask sackdz about that.
RTE117
Aug 25, 2005 11:09 AM
integrakilla
12
May 5, 2004 05:08 AM
miataguy
Jan 26, 2003 11:25 AM
