How to wire an amp and sub to stock integra HU?
Old Apr 27, 2003 | 09:07 AM
The Poopsmith's Avatar
Default How to wire an amp and sub to stock integra HU?
I have a kenwood kAC-829 amplifier and a pioneer sub I want to hook up to my integra. Right now I have a stock HU, but want a little bass in my system. I don't know anything when it comes to stereo electroincs, and I searched HT, Team-integra, and some other online places w/ no definate answer on how to wire them.
Could a stereo guru help me out and give me step by step instructions on how to do this?
Old Apr 27, 2003 | 10:22 AM
arsenaldragster's Avatar
Default Re: How to wire an amp and sub to stock integra HU? (DeeSeeToo)
go to any stereo shop and ask them for a Hi to a low level converter...get one of those..is comes with instructionsss...get a amp wire kit and plug in....very easy....
Old Apr 27, 2003 | 11:53 AM
Default Re: How to wire an amp and sub to stock integra HU? (arsenaldragster)
thanks, ill do that today
Old Apr 27, 2003 | 02:38 PM
HiRevn's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by arsenaldragster &raquo;</TD></TR><TR><TD CLASS="quote">go to any stereo shop and ask them for a Hi to a low level converter...get one of those..is comes with instructionsss...get a amp wire kit and plug in....very easy....</TD></TR></TABLE>
What's this hi to low converter look like? When a shop wired an amp to my stock HU, they had to cut the speaker outputs and used PAC adapters to convert them to RCA's. Then again maybe my situation was different since I had to run all my speakers through the amp.
Old Apr 27, 2003 | 02:47 PM
Default Re: How to wire an amp and sub to stock integra HU? (HiRevn)
yea, could you go in depth of how to do the install and how it works?
Old Apr 28, 2003 | 12:25 PM
cd5_2NR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HiRevn &raquo;</TD></TR><TR><TD CLASS="quote">
What's this hi to low converter look like? When a shop wired an amp to my stock HU, they had to cut the speaker outputs and used PAC adapters to convert them to RCA's. Then again maybe my situation was different since I had to run all my speakers through the amp.</TD></TR></TABLE>
yeah theres different ways to run it, its a little easier if you amp has inputs for speakers...then you can you ues the output side and do without RCA's...i'd go with the other way, get an adapter that goes from the HU and turns into RCA outputs...either way will work fine...
Old Apr 29, 2003 | 02:52 PM
duppykiller1's Avatar
Default Re: How to wire an amp and sub to stock integra HU? (zeROTWO_CG6)
Do you need a crossover for the sub?
Old May 1, 2003 | 08:32 AM
HiRevn's Avatar
Default Re: How to wire an amp and sub to stock integra HU? (duppykiller1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by duppykiller1 &raquo;</TD></TR><TR><TD CLASS="quote">Do you need a crossover for the sub?</TD></TR></TABLE>
I never had one, unless the amp has one built in to it, which I doubt. I could be wrong though.
Old May 1, 2003 | 09:25 AM
nOOber's Avatar
Features:
2-Channel Power Amplifier
100W x 2 at 4ohm 14.4V (0.8%THD)
150W x 2 at 2ohm 14.4V (0.8%THD)
300W x 1 Bridged 14.4V (0.8%THD)
Power indicator with blue LED
Built-in low-pass filter
Variable input sensitivity
Tri-mode operation
2 ohm load capability
Speaker level input for OEM upgrade
Gold-plated input/output terminals
Power MOSFET switching power supply
built in, so no worries.
Old May 1, 2003 | 11:35 AM
TrblPinoy1's Avatar
That PAC adapter is a Hi to low level adapter....the PAC is just a brand name
Old May 2, 2003 | 07:36 AM
Default Re: How to wire an amp and sub to stock integra HU? (TrblPinoy1)
so could somebody link me to a write up, or say how to install the sub? I want to make sure im not ******* anything up when I install it.
Old May 2, 2003 | 08:17 AM
o_Rage_o's Avatar
Default Wiring Stock HU to Amp using Line Level Converter
AMP RCAS
Take your line level input converter and wire it as per its instructions. Usually this involves tapping onto your left and right rear speakers and connecting them to this converter and then connecting rcas to it and running them to your amp. You should not need long rca runs because your doing all this in the trunk.
Remote Wire
The remote wire will turn on your amp when your deck is on, there should be a wire for this located right at the deck but since its stock your going to have to goto the Power Antenna wire, which is YELLOW/GREEN and located at the back of the radio harness (have fun taking out the radio..make sure you get the screw/bolt thats holding it back by getting on your knees from the passanger side and reaching up the back with a screwdriver praying to god you'll find it)
Fuses and Power Wire
You need to run the wire through the firewall to the battery to get the proper amount of current to your amp, you would'nt want to supply it with the small stock wiring made for the radio would you?
Connect wire to battery, cut it within 12"-14" of battery terminal (safety!) and run it straight to the back.
There are plugs on the firewall you can pop out on the passanger and drivers side near the kickpanels that you can pass wire through. Just make sure you use grommets, or cut a hole in the plug run it through and replace the plug (remember water can get through this hole and the chaffing of the wire against your chassis could cause it to short!!)
So now you hopefully have ran the remote wire and the power wire on ONE side of
the car. This way if you ever upgrade your stock deck you can use the other side to pass down real rca's (hell...buy $18 rca cables and save yourself the time by doing it now to rough it in if you like)
Connect the rcas from the line converter to the amp, connect the power wire and remote wire to the amp, set your gains around half, ground the amp to a nice solid bold in the trunk (sand it, dielectric grease it and use ring terminals and washers..also make the wire run as short as possible while still remaining comfortably hooked to the amp)
Turn it on, and it should work. The only thing i cannot verify right now is if the power anntenna automatically goes DOWN when you switch to CD player on the stock unit, if it does, you cannot use the Yellow/Green from the radio harness but you'll have to use Yellow (accessory) from the ignition harness, convientnly located at the front of the fuse panel near the right hand side.
Enjoy
-Rage
Old May 2, 2003 | 09:29 PM
Default Re: Wiring Stock HU to Amp using Line Level Converter (o_Rage_o)
thank you very much
o_Rage_o nicest guy in the audio forum
Old May 3, 2003 | 08:44 AM
I have RCA's for the amp
but since there are speaker level inputs already on the amp, do I just tap into the rear speakers and connect them to the amp w/o using a hi to low converter?
And when I tap into the rear speakers, what gauge should I use? and should I just splice?
Old May 3, 2003 | 12:04 PM
o_Rage_o's Avatar
Default Re: Wiring Stock HU to Amp using Line Level Converter (DeeSeeToo)
oh, if you already have speaker level line, you will not need a hi/lo connecter. Just splice into your rear speaker wiring, I'm not sure exactly how your speaker level line in's look (I've personally never used them...I'm not an installer, just an enthusiast), but you'd prob need to splice both the left and the right to get a stereo signal to the amp (although your sub should really be in mono)
Use whatever gauge you can find, 18 Should be great, anything bigger (ie. Lower gauge) is useless since it's Line level.
-Rage
Old May 3, 2003 | 12:12 PM
ok, i have 18-20 guage wire so I'm set w/ that. I guess its off to radio shack to get some electrical tape.
Old May 4, 2003 | 04:11 PM
intalled sub and amp today, everything went good, except ran out of wire! other then that the only problem I have is my battery voltage dropping while the amp is on, from 13.8-9 to 12.0. What does this mean, new alternator? the car also sputters and dies sometimes now...
Old May 5, 2003 | 08:06 AM
o_Rage_o's Avatar
eww.. um, turn on your car, let it run, disconnect your positive battery terminal post at battery..
if your car dies; new alternator time or your belts may need adjusting.
other than that, I have no clue...that amp shouldn't be a heavy current load
-Rage
gunsnbam
Audio / Security / Video
Feb 14, 2010 08:15 AM
jeff(s)
Apr 8, 2005 05:19 PM
xTurtle714x
Feb 2, 2005 06:20 PM
cougar10ag
Mar 23, 2004 07:14 PM
phreakmang
Mar 11, 2004 07:32 PM
