With this setup would i be able to hit 12's
Old Apr 25, 2003 | 05:49 PM
B16 BROTHER's Avatar
Default With this setup would i be able to hit 12's
I have a 00 b16 that I have already sent off to be sleeved by Darton. I have not bought anything else yet, I was think of : eagle rods, aries pistions, arp head studs, crower dual rate valve springs and titanium retainers, integra type R intake valves stock cams, skunk 2 intake manifold, rc 550'cc injectors and hondata s200 all being put down to the ground by clutchnet 6 puck and stock flywheel through a gsr tranny. My power adder is a max rev manifold, tial 35mm wastegate, vortec bov, t3/t4 with a .63 exhaust and 3 inch downpipe. I was wondering how much horsepower this set up would be capable of or maybe a estimate of what kind of times the set up would put down. Any help would be greatly appreaciated
Old Apr 25, 2003 | 08:33 PM
98civicEX's Avatar
Default Re: With this setup would i be able to hit 12's (B16 BROTHER)
all depends on how much boost, i'd be scared to use eagle rods from what i've been reading..but that's just my thoughts...also check to see how maxed those 550's are going to be. talk to your tuner would be the best bet.
Old Apr 25, 2003 | 08:53 PM
BoostedSi's Avatar
Default Re: With this setup would i be able to hit 12's (98civicEX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98civicEX &raquo;</TD></TR><TR><TD CLASS="quote">all depends on how much boost, i'd be scared to use eagle rods from what i've been reading..but that's just my thoughts...also check to see how maxed those 550's are going to be. talk to your tuner would be the best bet.</TD></TR></TABLE>
What have you been reading about eagle rods??? They've worked great for me for 2 years.
Old Apr 25, 2003 | 09:20 PM
-iLLuZioN-B18C1's Avatar
i say you could hit 12's, if you boost enough. nice set of slicks would also help alot!
Old Apr 25, 2003 | 09:43 PM
EVIL_AWD's Avatar
Default Re: With this setup would i be able to hit 12's (jvithayapun)
Yeah, what's with everybody putting down Eagle rods? I also have Eagle rods and haven't had any problems. I thought Eagle made a quality set of rods? Someone please fill me in on their experiences with Eagle rods, good or bad. It seems from what I have been reading lately people are saying they suck, but why?
Old Apr 25, 2003 | 10:19 PM
B18C1_T's Avatar
Default Re: With this setup would i be able to hit 12's (ITR420)
eagle rods are good its just that the rod bolts will let go it your not using moly lub to torque it up to arp rod bolts specs (28lbs) or if you over torque them it can also weaken the bolt ends which is pretty thin...this is from my experience
Old Apr 27, 2003 | 02:04 AM
LsVTeCTuRBo17's Avatar
I made 650 hp 450tq in my street car with eagle rods I have had no problems with them
Old Apr 27, 2003 | 07:47 AM
keebler65's Avatar
Default Re: With this setup would i be able to hit 12's (B18C1_T)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18C1_T &raquo;</TD></TR><TR><TD CLASS="quote">eagle rods are good its just that the rod bolts will let go it your not using moly lub to torque it up to arp rod bolts specs (28lbs) or if you over torque them it can also weaken the bolt ends which is pretty thin...this is from my experience</TD></TR></TABLE>
sounds more like operator error to me....
Old Apr 27, 2003 | 08:15 AM
BlueSi2k's Avatar
Default Re: With this setup would i be able to hit 12's (keebler65)
One person said they sucked and everyone else jumped on the bandwagon without their own personal experience. So many people have had good experiences w/ their eagles and i have a set waiting to go into my new motor...
Old Apr 27, 2003 | 08:21 AM
Thank you all for the input. I belive that I am going to give the eagles a try.
Old Apr 27, 2003 | 08:23 AM
hatchback19's Avatar
A friend of mine is pushing 800hp with Eagle rods in his DSM, I can't imagine them being much differant then from the rods they make for Hondas.
Old Apr 27, 2003 | 01:53 PM
EVIL_AWD's Avatar
Default Re: (hatchback19)
I figured one person had a bad experience with them, which was probably installers error and then they said something, at which point everyone else just junped on the bandwagon. That's usually how quality parts get a bad rep. I'll continue to use Eagle rods in my motors
christian7750
79
Mar 18, 2009 03:59 PM
92DAturboteg
Aug 12, 2006 07:09 AM
Sl0wEK
Jun 9, 2006 05:13 PM
koolaid3246
May 9, 2006 05:42 PM
30psi Teg
Nov 19, 2003 09:10 AM
