Speedo is waaaay off after swap?
Old Apr 24, 2003 | 05:54 PM
Jonathan_ED3's Avatar
Default Speedo is waaaay off after swap?
While driving around today, I noticed my speedo is wayyy off.
While I'm going ~35, the speedometer says that I'm going ~55-60mph or so.
What would be causing this? It was fine before the swap, and the cluster hasn't been touched whatsoever.
Any ideas?
Old Apr 24, 2003 | 06:03 PM
fastwanabe's Avatar
Default Re: Speedo is waaaay off after swap? (hot_EG)
I have the same problem, when I'm doing 65mph my speedo says I'm doing 75 or so. When I'm doing 100 my speedo says 115mph, I've always figured it was the size of my tire and rim throwing it off. What is the size for the stock wheels and tires on a LUDE?
Old Apr 24, 2003 | 06:09 PM
poison's Avatar
Default Re: Speedo is waaaay off after swap? (fastwanabe)
ya. i'm having the exactly same issue. My speedo is about 7-8 MPH off.
the stock lude tires from 92-95 were 205/55R15's I believe.
For the Type SH's, they came with 16's.
Old Apr 24, 2003 | 06:15 PM
hondaeg5's Avatar
Default Re: Speedo is waaaay off after swap? (poison)
what are you using to measure your actual speed?(how do you know your off?)
Old Apr 24, 2003 | 06:16 PM
poison's Avatar
Default Re: Speedo is waaaay off after swap? (hondaeg5)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondaeg5 &raquo;</TD></TR><TR><TD CLASS="quote">what are you using to measure your actual speed?(how do you know your off?)
I paced my car with my friend's brand new street bike as well as other vehicles.
Old Apr 24, 2003 | 06:19 PM
hondaeg5's Avatar
good to know.(i have enough speeding tickets lol). ill have to check mine once its all together.
Old Apr 24, 2003 | 06:20 PM
poison's Avatar
LOL. what's funny is, i usually drive about 8-9 over the speed limit, and I have never gotten a speeding ticket with my swap..
wonder why? probably because I'm driving the exact speed limit LOL =X
Old Apr 24, 2003 | 07:09 PM
Newman's Avatar
New User
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by poison &raquo;</TD></TR><TR><TD CLASS="quote">LOL. what's funny is, i usually drive about 8-9 over the speed limit, and I have never gotten a speeding ticket with my swap..
wonder why? probably because I'm driving the exact speed limit LOL =X</TD></TR></TABLE>
Bah... just go the flow of traffic and don't stick out like a sore thumb and you'll be fine. BTW, stock Prelude has a 65 series tire, so the rotational diameter is greater, thus throwing your speedo off 8-9%. But what you said originally about going 35mph, and the speedo saying 55, then it sounds like there's something else wrong.
Old Apr 24, 2003 | 07:24 PM
poison's Avatar
Default Re: Speedo is waaaay off after swap? (Newman)
Hmm, 15x6.5 with 195/50R15's have around same rotational diameter?
You sure it's 65 series? That's friggin huge. I believe it's 60 for the Prelude Si and Prelude VTEC.
Old Apr 24, 2003 | 07:40 PM
hmmm, it might not be as far off as I'm thinking it might be (I haven't paced with another car yet), but it's for sure off by a larger degree than I'd like.
It's not really a big problem, it's just annoying. I like to keep track of my actual MPG, and the speedo being this far off makes it pretty hard to do that.
So if I get the same overal diameter tires as what the prelude would come, the speedo will be accurate? Cuz it's for sure VERY annoying to me. lol.
Old Apr 24, 2003 | 07:42 PM
Newman's Avatar
New User
Heh, I didn't say the same, I said greater rotational diameter than a 15" rim w/50 series tire
60 series, 65 series.... eitherway but like what somebody else said, it's not a 55-series tire on the Prelude. But that's still generally the reason why the speedo is slightly off with a H22 swap, using the H22 VSS.
Old Apr 24, 2003 | 07:56 PM
poison's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Newman &raquo;</TD></TR><TR><TD CLASS="quote">Heh, I didn't say the same, I said greater rotational diameter than a 15" rim w/50 series tire
60 series, 65 series.... eitherway but like what somebody else said, it's not a 55-series tire on the Prelude. But that's still generally the reason why the speedo is slightly off with a H22 swap, using the H22 VSS.</TD></TR></TABLE>
true dat. damnit, looks like i'm gettin 80 series tires on my 14" steelies
Old Apr 24, 2003 | 08:27 PM
hmmm. I see...sorta.
what size would I have to get, with say a 16" for it to be accurate? Or even a 15" at that?
Old Apr 24, 2003 | 08:32 PM
fastwanabe's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Newman &raquo;</TD></TR><TR><TD CLASS="quote"> But that's still generally the reason why the speedo is slightly off with a H22 swap, using the H22 VSS .</TD></TR></TABLE>
Newman, if I could use a b series tranny VSS would that make it more accurate? Are the H and B series VSS's even swappable?
poison's Avatar
Yeah, 16x7 rims with 40 series would have pretty close rotational diameter.
Old Apr 24, 2003 | 08:45 PM
I guess I don't understand how the sizes play into the diameter.
I was hoping to run 195-50-15's....how far off would that be?
Old Apr 24, 2003 | 08:52 PM
fastwanabe's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by poison &raquo;</TD></TR><TR><TD CLASS="quote">Yeah, 16x7 rims with 40 series would have pretty close rotational diameter.</TD></TR></TABLE>
I run 205/40/16 and I'm still off by 10mph(my guess)
Old Apr 24, 2003 | 08:55 PM
poison's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fastwanabe &raquo;</TD></TR><TR><TD CLASS="quote">
I run 205/40/16 and I'm still off by 10mph(my guess)</TD></TR></TABLE>
dayam. looks like we're all screwed unless we run some blinging 18" rims with 40 series
Old Apr 24, 2003 | 09:27 PM
aah, crap.
Old Apr 25, 2003 | 06:21 AM
EK22Tim's Avatar
LOLOL!! I thought it was just me!! that's good to hear it's not. anyway, mine's off by 5 now with my 205 series 15's. It WAS off by 9 with my 14's. Oh well. I do the conversion in my head automatically now.
Old Apr 25, 2003 | 09:54 AM
Turbogixxer's Avatar
I paced my car with my friend's brand new street bike as well as other vehicles.</TD></TR></TABLE>
My bike is off by 3 mph at 50 and 11mph at 175. all bike speedo are off.
Old Apr 25, 2003 | 07:20 PM
Jawad.'s Avatar
Default Re: Speedo is waaaay off after swap? (turbogixxer)
is it not possible to recalibrate the speedometer?
Old Apr 26, 2003 | 06:01 AM
Fuster_Cluck's Avatar
Default Re: Speedo is waaaay off after swap? (Jawad)
How do you guys figure the wheel diameter is the cause of the speedometer to read inaccurate?
I believe my civic speedo was reading accurate before the swap. But, last night I knew it was off and tested it with a friends BMW. I'm reading 80 when she's doing 72mph. I just dropped a GSR in my EG so I am betting it's the new motor.
I have a GSR cluster waiting to go in. Will the GSR cluster give me an accurate reading of my speed?
Thanks!
civic91
May 3, 2009 10:55 AM
davefromPA
Jan 22, 2008 05:45 PM
Fomoco
Jun 6, 2006 02:54 PM
jerm001
12
Apr 2, 2006 03:20 PM
fullraceacura
10
Jan 17, 2005 10:34 AM
