speedometer trouble
speedometer trouble
My speedometer is registering a little fast. it was a swap from an LX. i have a CX. 94. i wanted a tach.
so my question is, how do i re-calculate my speedometer?
also. when my tank is full it registers that it is only a half full. how do i fix that?
1 Post
Re: speedometer trouble (davefromPA)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by davefromPA »</TD></TR><TR><TD CLASS="quote">
Change your tire size.
I dont know that there is a way to change the speedometer
Re: speedometer trouble (z6hatchboy)
stock rims. stock tire size.
car that it came off of was the same size tire as mine.
anybody know what the stock tire size for a 92 LX is?
+its not the vss that is off... its the actual gauge cluster. now you can pull it out and try to manually adjust it... like if it's saying you are going fifty but really going 40 you can move the needle down i believe and vice versa...
A friend of mine did that don't know how well it worked but thats always an option to try or you can try a new gauge cluster and see if that fixes it.
And you saying your fuel gauge is messed up it might be that you have a bad cluster.
since 2 things are wrong on the cluster it could be that it is just bad. Also try pulling it out and unplugging and then plugging all the plugs in all the way see if that does anything
JohnD1079
04-04-2007 08:27 PM
rasinhell
01-23-2007 12:51 AM
jerm001
12
04-02-2006 03:20 PM
hondaracin24
09-16-2004 02:27 PM
