systoms of bad valves..
Old Apr 24, 2003 | 02:26 PM
allmotorls95's Avatar
Default symptoms of bad valves..
what would the compression test reveal if i have a bad valve???
Old Apr 24, 2003 | 04:20 PM
JDMH22HATCH's Avatar
Default Re: symptoms of bad valves.. (allmotorls95)
It just depends on what happended. If you run a compression test you will notice quite a bit of variance between the good cylinders and the bad. I have a slightly bent valve right now and the compression is a little off in one cylinder. My buddy chipped a little piece off of one of his valves and when doing a compression test that cylinder registered at 35. The car still ran ok, but idled messed up when at dead stop. Just remember there is a slight variance between each cylinder so don't freak out if it is off by just a little bit. What are the symptoms?
Old Apr 24, 2003 | 04:37 PM
Chris's Avatar
Default Re: symptoms of bad valves.. (JDMH22HATCH)
leakdown test will show bad valves.
Compression test will show bad Rings.
Smoke at idle and startup= valves
Smoke at High RPM and heavy loads = Rings
Vladglad
20
Dec 18, 2013 02:56 PM
Sport_Injected
Aug 25, 2004 09:21 PM
RGoose18
May 21, 2004 10:13 AM
Goldfingiz
Dec 13, 2002 10:30 PM
lsvtec42
Dec 6, 2001 12:39 PM
