99-00 swap guru's need help fast!!!!
Old Apr 24, 2003 | 07:57 AM
HybridHatchC1's Avatar
Default 99-00 swap guru's need help fast!!!!
my neighbor is in the middle of a swap hes got a 2000 ex and hes swaping in a 98 gsr, which wiring harness should he use, also if somone has a diagram that would be much appreciated, thanks Tim
Old Apr 24, 2003 | 09:52 AM
Default Re: 99-00 swap guru's need help fast!!!! (HybridHatchC1)
anyone help!! please!!!!
Old Apr 24, 2003 | 12:17 PM
Trey's Avatar
25 Year Member
Use the Civic Harness since it's one piece and the teg is two piece. check the link in my sig for the other parts he'll need.....
Old Apr 24, 2003 | 07:01 PM
nyEKhatch's Avatar
Default Re: 99-00 swap guru's need help fast!!!! (Trey)
Hey, use Trey's swap guide it is the sh*t. Oh and Trey I
just realized why my swap won't idle and I'm getting a
engine code for IAC, I didn't move the pin for it!!!
From a 14 to a12, I am a dumb as*!!
Just want to say thanx for the guide, helped alot.
Old Apr 24, 2003 | 09:08 PM
Fowler.'s Avatar
Default Re: 99-00 swap guru's need help fast!!!! (nyEKhatch)
The easiest harness to use would be t he 99-00 Si harness. You'd only have to add the wires for the secondary buttlerflies. Everything else would be kosher.
Good luck.
Apr 9, 2018 05:14 PM
SanFranGunners
Apr 16, 2008 02:47 AM
sant0r0
Aug 16, 2005 11:43 AM
JDM Approved
Nov 10, 2004 03:21 PM
