Best turbo to use ?
OK i am about to start building my own turbo set up for my car.. i need to know what turbo u guys would use..
My set up
Gsr Motor,Skunk2 manifold,str fuel rail, hondata S200 with boost.. i want to be able to push alot of HPs out of her,Im gonna fully build the motor to run 20 plus but not till winter, so for now i just wanna buy a turbo that will run good and later
i can up the boost without having to change turbos,,
So keep in mind i need one to run 10 psi for now then 20 plus later.. what would u use???
THanks
My set up
THanks
T04E 50-Trim compressor paired with a stage III turbine wheel in a .63 A/R housing.
http://store.yahoo.com/cheaptu....html
