need to know asap MSD dis. cap
Old Apr 24, 2003 | 06:04 AM
jdhealy's Avatar
Default need to know asap MSD dis. cap
ok im missing the spring in the distributor cap and if i get the MSD cap do i still need the spring or not i need to know soon so i can order it
Old Apr 24, 2003 | 06:14 AM
Stew Pidasso's Avatar
Default Re: need to know asap MSD dis. cap (jdhealy)
No
Old Apr 24, 2003 | 06:25 AM
Xsi's Avatar
Xsi
Are you converting to an external coil?
Old Apr 24, 2003 | 07:10 AM
jdhealy's Avatar
Default Re: need to know asap MSD dis. cap (Xsi)
"NO" as in it will work i dont need the spring or "NO" my car wont work and i need to find soemthing different.
if the MSD cap will work i will convert to external...all i need it cap and coil and wire right???
Old Apr 24, 2003 | 07:28 AM
Xsi's Avatar
Xsi
If you're converting to an external coil you wont need the spring/electrode. You'll need the coil and wire and you'll need the cap if you're not going to modify your stock cap.
Try my website for installation info
Old Apr 24, 2003 | 08:56 AM
I apologize. I was directly answering your question. You do not need the spring in the old cap. The MSD cap works great and even comes with mounting hardware. Just make sure when you get the external coil for the MSD that you get/use a coil with a ballast resistor with it. I used a Blaster 2 coil with mine.
Old Apr 24, 2003 | 10:05 AM
jdhealy's Avatar
Default Re: need to know asap MSD dis. cap (Stew Pidasso)
wheres that chaepest place to get it or the best whatever
use the blaster SS or blaster 2 coil with it witch one is cheaper??? what one to get
and what is a ballast resistor where do i get it and what dose it do???
also i still need a rotor right??
Old Apr 24, 2003 | 10:43 AM
I got mine from http:// summitracing.com just because I live by them. You would probably be better off shopping around though. I used one on my Accord and I got a new one for my H22A. They do have these really cool looking clear red ones now but they're more money for the bling...
I used the Blaster 2 coil with mine. You can get a universal chrome mounting kit from a local auto parts store. Just make sure you get part # MSD8200 . That one comes with the ballast resistor I told you to get. I bought the one without first and then I had to go all the way back to get a ballast resistor separately.
Old Apr 24, 2003 | 10:50 AM
Here's a picture of the red cap. Yes you need a rotor but the stock one is what you use. A ballast resistor limits the current going to the coil. It goes in between your 12V source and the 12V (power) input on the coil. I didn't know this at first and that coil got so damn hot in a few seconds...
For more info, go to http://www.msdignition.com/
Old May 1, 2003 | 09:56 PM
Datum1Tuning
Guest
Posts: n/a
I got a set for sale.....
radicaled434
Apr 21, 2013 07:15 AM
dmotoguy
Jul 29, 2008 08:22 PM
honda_SiRII94
Apr 9, 2007 08:14 AM
turbo sol
May 5, 2003 06:38 AM
