My LS Turbo 1/4 Mile times...What do you think?
Old Apr 23, 2003 | 06:56 PM
B18PoweredCivic's Avatar
Default My LS Turbo 1/4 Mile times...What do you think?
Setup:
96 Civic EX- Weight 2550 lbs w/ driver
Stock b18b...6 puck clutch...
2 1/2 Cat Back...Hondata s200 with DSM 450 and Holley Fuel Pump
Falken Azenis Drag Radials
First 2 runs were @ 8 psi
Last 2 were at 10-11 psi
My times were:
1st Run
r/t- .870
60'- 2.571
330- 6.445
1/8- 9.518
mph- 80.71
1000- 12.187
1/4- 14.395
mph- 102.39
2nd Run
r/t- .629
60'- 2.428
330- 6.254
1/8- 9.254
mph- 82.54
1000- 11.850
1/4- 14.022
mph- 103.77
3rd run
r/t- .643
60'- 2.332
330- 6.120
1/8- 9.065
mph- 83.13
1000- 11.612
1/4- 13.733
mph- 106.24
4th and best run
r/t- .755
60'- 2.340
330- 6.000
1/8- 8.883
mph- 85.66
1000- 11.400
1/4- 13.527
mph- 105.87
What do you guys think...?...What do you think ill do with slicks?
Old Apr 23, 2003 | 06:59 PM
DIRep972's Avatar
Smarter than you
Default Re: My LS Turbo 1/4 Mile times...What do you think? (B18PoweredCivic)
good mph, With pracetice I think even on azenis you could go a good bit faster.
Old Apr 23, 2003 | 07:00 PM
94dxt's Avatar
improved each run slicks= probably close to 13.0
Old Apr 23, 2003 | 07:01 PM
Default Re: My LS Turbo 1/4 Mile times...What do you think? (IRepD)
Yeah...I was very suprised at my MPH..Normally its around 97-99 mph
Old Apr 23, 2003 | 08:31 PM
93LSivic's Avatar
Check the sig. you can do better....practive those 60's !
Old Apr 23, 2003 | 09:01 PM
roydogg's Avatar
Default Re: My LS Turbo 1/4 Mile times...What do you think? (93LSivic)
Pretty good What's your setup? You didn't mention what kit your using. Internals stock?
Old Apr 23, 2003 | 10:12 PM
SIK IN DA HED's Avatar
New User
Default Re: My LS Turbo 1/4 Mile times...What do you think? (94dxt)
progressing... good times!
Old Apr 23, 2003 | 10:21 PM
V-SPEC 1's Avatar
That's pretty good #s. I hope to get similar # for my friend 95 civic coupe LS built bottom end stock sleeve and head.
Old Apr 23, 2003 | 10:35 PM
UberTeg's Avatar
wow, falken now makes azenis in drag radial trim? Good times tho! I hope i run simialr with my setup
Old Apr 24, 2003 | 06:28 AM
Default Re: My LS Turbo 1/4 Mile times...What do you think? (roydogg)
Yeah stock internals with a Drag Kit...t3/t4e turbo
Old Apr 24, 2003 | 06:50 AM
hulkhb's Avatar
alot of room for improvement, put that bitch on a diet too.
Old Apr 24, 2003 | 08:19 AM
The Crow's Avatar
Default Re: My LS Turbo 1/4 Mile times...What do you think? (hulkhb)
I see slicks in your future!
Old Apr 24, 2003 | 08:23 AM
maxpsi's Avatar
Default Re: My LS Turbo 1/4 Mile times...What do you think? (The End)
good job
Old Apr 24, 2003 | 09:43 AM
WOThrilla's Avatar
r/t- .755
60'- 2.340
330- 6.000
1/8- 8.883
mph- 85.66
1000- 11.400
1/4- 13.527
mph- 105.87
What do you guys think...?...What do you think ill do with slicks?[/QUOTE]
-i would say with 22'' slicks you would be in the 13.0-13.2 area. my friend runs an LS turbo in his 99si and ran a 2.0 60ft with a 104 trap at 13.4et. thats 3/10 off the 60ft right there, and you trap higher
HamiltonRex
Jun 11, 2006 07:10 AM
boost fed ls
Apr 4, 2004 10:42 AM
Adi Radoncic
Jun 10, 2002 08:40 AM
pagong
May 9, 2002 11:36 PM
