11.1 compression
Old Apr 23, 2003 | 05:36 PM
redteg's Avatar
Default 11.1 compression
i am running 11.1 compression will i have any problems with pinging or anything else. i live in the northeast and i use 93 and94 octain but since we have cold winters they put preservatives in the gas in the winter. will this effect my mtor.
Old Apr 23, 2003 | 05:50 PM
ITR21's Avatar
Default Re: 11.1 compression (redteg)
just keep putting the 93 and 94 octane fuel in and enjoy your car
Old Apr 23, 2003 | 05:51 PM
rated_r's Avatar
Default Re: 11.1 compression (ITR21)
Old Apr 23, 2003 | 07:25 PM
non-VTEC's Avatar
11:1 isnt high enough to worry about dentonation.......
Old Apr 23, 2003 | 07:27 PM
Rguy's Avatar
Voted Best Looking GDD Poster
25 Year Member
Community Builder
Community Influencer
Active Streak: 60 Days
Wont be a prob at all, im sure lots of cars in your area run even higer compression...IE, S2000...
B16CRX's Avatar
Default Re: 11.1 compression (non-VTEC)
With 93-94 oct you will be fine. I'm still trying to decide if I can go that high with only 91 out here.
Edit: How high is too high for 91 oct?
Old Apr 23, 2003 | 07:29 PM
redteg's Avatar
Default Re: 11.1 compression (B16CRX)
thanks a lot for all the info. the only thing that i wasquestioning is the winter out here they put those damn preservetives in the gas to keep it from freezing.
Old Apr 23, 2003 | 08:53 PM
ScottFern's Avatar
what is the highest cr you can go on 93 octane ?? CTR pistons in a GS-R block ?
I heard there was a clearance issue with the CTR in gsr block ?
Old Apr 23, 2003 | 09:19 PM
real9999's Avatar
The northeast isn't the only place with cold winters. There are plenty of others. You'll be fine.
Tom
Old Apr 23, 2003 | 09:30 PM
Rob Dizzle's Avatar
Default Re: 11.1 compression (real9999)
I have 11.5ish and on 91 octane. even untuned using the hondata basemap I had zero problems
Old Apr 23, 2003 | 10:19 PM
Calavera's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B16CRX &raquo;</TD></TR><TR><TD CLASS="quote">With 93-94 oct you will be fine. I'm still trying to decide if I can go that high with only 91 out here.
Edit: How high is too high for 91 oct?</TD></TR></TABLE>
People here in socal are going up to 12:1 with 91oct gas here. But you really shouldn't go higher than that IMO.
Old Apr 23, 2003 | 10:27 PM
ScottFern's Avatar
Default Re: 11.1 compression (Calavera)
I would assume on a b18c1 JDM ITR pistons would suffice ?
Old Apr 23, 2003 | 10:56 PM
B16CRX's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Calavera &raquo;</TD></TR><TR><TD CLASS="quote">
People here in socal are going up to 12:1 with 91oct gas here. But you really shouldn't go higher than that IMO.</TD></TR></TABLE>
That makes me feel a little better. I'll probably be at 11.8:1 max, tuned with Hondata.
norcalbayboy
29
Aug 7, 2006 10:08 PM
EliTe 93Lude
Jul 31, 2006 07:18 PM
pinoy369
15
Mar 2, 2006 10:39 PM
Kev95lx
Dec 7, 2002 12:37 PM
Rocket
May 5, 2002 12:32 PM
