Header bolt broke off while tightening
Old Apr 23, 2003 | 10:03 AM
BeesDA6's Avatar
Default Header bolt broke off while tightening
Whats the best thing to do with my broken bolt ? It broke off when i was tightening it.
Old Apr 23, 2003 | 10:08 AM
J337_UNIT's Avatar
Default Re: Header bolt broke off while tightening (BeesDA6)
drill it out and re-tap
Old Apr 23, 2003 | 10:22 AM
tC_Dragon's Avatar
Default Re: Header bolt broke off while tightening (J337_UNIT)
its a bolt? i thought it was a stud.. .hmm watever.. but either way.. u probably have to drill dat sucker out and rethread the inside of it.
Old Apr 23, 2003 | 10:32 AM
emr88's Avatar
Default Re: Header bolt broke off while tightening (pdcdragon)
Bet it was one of the lower left studs right?
Seems to be a semi-common problem. Anyways, it's a stud not a bolt. You'll need to extract it out and replace it. Not fun if you don't have the right tools. The stud itself should be cheap from Acura, however getting it out can be a real PITA.
My advice, take it to a H-A Specialist that already has the tools to do it right.
Old Apr 23, 2003 | 11:34 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
I broke the one closest to the distributor, I bet that's the one you broke, too. That was over a year ago and I haven't had any problems. Next time I drain my radiator I might take it out and remove the bumper so I'll have room to get a drill and screw extractor in there.
Old Apr 24, 2003 | 08:01 AM
BeesDA6's Avatar
Default Re: Header bolt broke off while tightening (emr88)
It was a bolt (GS) Actually the top right. It would of been all good but now i can hear alittle bit of a leak when im at full throttle. So I guess ill have to do some extracting.
Old Apr 25, 2003 | 03:38 PM
allm0torGSR's Avatar
My far left stud also broke when my header was installed.
Old Apr 25, 2003 | 06:21 PM
Turbo Powa's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by emr88 &raquo;</TD></TR><TR><TD CLASS="quote">Bet it was one of the lower left studs right?
Old Apr 26, 2003 | 11:00 AM
integra15's Avatar
Default Re: Header bolt broke off while tightening (USDMDC2NH)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by USDMDC2NH &raquo;</TD></TR><TR><TD CLASS="quote">My far left stud also broke when my header was installed.</TD></TR></TABLE>
Me too. I wonder why this one stud seems so often?
Old May 7, 2003 | 09:50 PM
Freelance-GSR's Avatar
Default Re: Header bolt broke off while tightening (integra15)
mine too but not by me
Old May 8, 2003 | 01:39 PM
asianautica's Avatar
Default Re: Header bolt broke off while tightening (Freelance-GSR)
Mine broke awhile a go. There were some leak in the begining cuz I reused the gasket. But ever since I put in the new gasket, ther has been no more leak. I think the new gasket expanded and seal the leak. It's also the top left stud.
Old Jul 17, 2003 | 04:16 PM
dwnthehatch's Avatar
Default Re: Header bolt broke off while tightening (asianautica)
Did you ever get it out? I just pulled the heat shield off of the exhaust manfold on my gsr swap I just got from IAS and noticed two nuts were missing, one bolt was snapped and there is some sort of sealant all over the gasket. I left Larry Jr a message but I doubt he will do anything about it.
Here's some pics:
Old Jul 17, 2003 | 04:40 PM
cccccccc's Avatar
same thing happened
im gonna go get a new stud from acura tommorow
Old Jul 17, 2003 | 04:44 PM
.RJ's Avatar
.RJ
Default Re: (c13r)
when you remove them, soak in PB blaster first. Then to remove them, put a socket on it and lightly tap with a hammer to break it loose. Apply anti seize when putting them back in.
spidermancivic
Aug 11, 2007 08:17 AM
truevietluv636
11
Jun 6, 2007 07:13 AM
akademikz26
Aug 23, 2006 04:28 PM
