tuning with afc, does it mess with ur timing?
Old Apr 22, 2003 | 10:50 AM
hybridb18's Avatar
Default tuning with afc, does it mess with ur timing?
when u use an afc to tune any kind of setup, does it mess with the engine timing when u take fuel off and add fuel on. cause it uses the map sensors voltage to control the fuel. and the map sensors voltage changes as the vaccume in the engine changes. i dont know, someone set me straight on this please. thanks
Old Apr 22, 2003 | 11:36 AM
BabyDaddy's Avatar
Default Re: tuning with afc, does it mess with ur timing? (hybridb18)
nope. doesn't change the timing. all it does is alter the voltage that the ecu sees from the sensor. that's how it changes the mixture.
Old Apr 22, 2003 | 12:38 PM
dfoxengr's Avatar
Default Re: tuning with afc, does it mess with ur timing? (BabyDaddy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BabyDaddy &raquo;</TD></TR><TR><TD CLASS="quote">nope. doesn't change the timing. all it does is alter the voltage that the ecu sees from the sensor. that's how it changes the mixture.</TD></TR></TABLE>
NO
Old Dec 31, 2003 | 02:53 PM
jazz215's Avatar
Default Re: tuning with afc, does it mess with ur timing? (hybridvteceg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hybridvteceg &raquo;</TD></TR><TR><TD CLASS="quote">
NO</TD></TR></TABLE>
no he's wrong, or no it does not change timing?
Old Dec 31, 2003 | 06:16 PM
Bailhatch's Avatar
Default Re: tuning with afc, does it mess with ur timing? (jazz215)
it doesn't change the timing. If only the afc could pull timing, if only!!!
Old Dec 31, 2003 | 07:07 PM
fulldragcrx's Avatar
Default Re: tuning with afc, does it mess with ur timing? (Bailhatch)
uh, yes it does. An AFC or VAFC alter the signal from the map sensor. Well guys the ecu looks to the map sensor to monitor engine load. to make a long story short, the ecu takes that value and looks up the best fuel and ignition map for that load point. So YES it does alter timing.
Old Jan 1, 2004 | 02:15 PM
Bailhatch's Avatar
Default Re: tuning with afc, does it mess with ur timing? (fulldragcrx)
yes your right but it doesn't help (retard) timing for a turbo car. Are the ignition maps 100% tied to the fuel maps or are there other inputs that affect timing independent of MAP voltage, like TPS or rpm?
Old Jan 1, 2004 | 06:08 PM
Yes, timing is direcly tied to fuel map. TPS, MAP, TDC, RPM alter any one of these and youll change both fuel and timing. unless you go to a stand alone ECU or if you could some how lock out your timing like the old muscle car guys used to...
Old Jan 1, 2004 | 11:16 PM
jazz215's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bailhatch &raquo;</TD></TR><TR><TD CLASS="quote">yes your right but it doesn't help (retard) timing for a turbo car. </TD></TR></TABLE>
thats what i was hoping for
Old Jan 2, 2004 | 10:50 AM
CHEETAH's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hybridb18 &raquo;</TD></TR><TR><TD CLASS="quote">when u use an afc to tune any kind of setup, does it mess with the engine timing when u take fuel off and add fuel on. cause it uses the map sensors voltage to control the fuel. and the map sensors voltage changes as the vaccume in the engine changes. i dont know, someone set me straight on this please. thanks</TD></TR></TABLE>
yes it does because ecu map loads (which is the input that the VAFC changes) are also timed to ECU ign timing maps not just fuel maps.
Greg
flamega
Feb 7, 2007 08:04 AM
BoostedD15B7
Feb 29, 2004 04:23 PM
darylfiend11
Aug 31, 2003 09:45 PM
BlueSi2k
Nov 18, 2002 01:31 PM
cjblmr
Nov 12, 2002 06:41 AM
