Turbo B16 guys, How to gain 14whp for 150.00- Tell me if Im right
Old Apr 22, 2003 | 05:49 AM
FredoSP's Avatar
Default Turbo B16 guys, How to gain 14whp for 150.00- Tell me if Im right
Okay here goes
I saw a post on clubsi where stock B16 cams were switched with GSR cams, the kid said it he got a net gain of 8whp and 1 tq. (say 90.00)
Then I was thinking a Hondata intake mani gasket, i cant remember exactlythe gain but lets say 5-6 whp and i dunno about TQ. (say 65.00)
Is this really far off or does it make sense?
Thanks - Fred
Old Apr 22, 2003 | 06:23 AM
b18cya's Avatar
yea, those gsr cams are suprisingly good for boost. uprade the valvesprings/retainers & they make power well past the stock rev limit with boost.
Old Apr 22, 2003 | 07:05 AM
1337 Si's Avatar
Default Re: (b18cya)
I plan on probally doing that too, that is if I don't get Crower cams first.
Old Apr 22, 2003 | 08:03 AM
FredoSP's Avatar
Default Re: (Boosted Ego)
well the point im trying to bring out is that you dont have to spend a lot of $ to gain 14 whp ... get me? GSR cams + Hondata intake mani gasket
Old Apr 22, 2003 | 08:12 AM
T-Blaze's Avatar
I made 90whp by adding my turbo to my B16 at 6psi.. So thats 15whp per pound...
1 pound of boost = 15 psi - and wiv a home made boost controller ($5) that's 15whp for $5.... Now that sounds more like it ;oP
Old Apr 22, 2003 | 08:30 AM
VaporTrail's Avatar
New User
Default Re: (T-Blaze)
yes but that has it's limits depending on where you are at already. Fuel system and bottom end limitations. I think he was talking about power without raising boost
Old Apr 22, 2003 | 08:52 AM
maxpsi's Avatar
Default Re: (VaporTrail)
How is this possible?
Old Apr 22, 2003 | 09:03 AM
I Like Boost's Avatar
Default Re: (maxpsi)
how is what possible??
Old Apr 22, 2003 | 09:10 AM
alpha's Avatar
Default Re: Turbo B16 guys, How to gain 14whp for 150.00- Tell me if Im right (FredoSP)
You are correct. He made 8whp (peak) and 1ft-lb (peak). He lost a little power down low too. I don't recall how much but it couldn't have been more than 3whp. He paid $75.00 for the used set.
Old Apr 22, 2003 | 10:27 AM
maxpsi's Avatar
Default .
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IMPULSE B18C-T &raquo;</TD></TR><TR><TD CLASS="quote">how is what possible??</TD></TR></TABLE>
Reread the thread.
Old Apr 22, 2003 | 11:44 AM
FredoSP's Avatar
Default Re: Turbo B16 guys, How to gain 14whp for 150.00- Tell me if Im right (0x64)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 0x64 &raquo;</TD></TR><TR><TD CLASS="quote">You are correct. He made 8whp (peak) and 1ft-lb (peak). He lost a little power down low too. I don't recall how much but it couldn't have been more than 3whp. He paid $75.00 for the used set.</TD></TR></TABLE>
yeah and then I thought to gain somemore power WITHOUT TOUCHING THE BOOST LEVEL u could add the hondata intake mani gasket and squeeze more out. I this might have constraints per your setup, but i thought it was something to post and see what other people thought. I mean if this does work that the price isnt that bad, IMO.
Old Apr 22, 2003 | 12:08 PM
ricodemus's Avatar
I'm hoping to get nice gains with the gsr cams over the 1st gen b16 cams, since they are supposed to be the weakest vtec cams other than the auto ones.
Is it true you need longer studs for the IM if you use the hondata heatshield?
Old Apr 22, 2003 | 12:49 PM
FredoSP's Avatar
Default Re: Turbo B16 guys, How to gain 14whp for 150.00- Tell me if Im right (ricodemus)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ricodemus &raquo;</TD></TR><TR><TD CLASS="quote">
Is it true you need longer studs for the IM if you use the hondata heatshield?</TD></TR></TABLE>
I have no clue .. up
Old Apr 22, 2003 | 12:52 PM
b18bturbo's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FredoSP &raquo;</TD></TR><TR><TD CLASS="quote">
I have no clue .. up</TD></TR></TABLE>
yes it is true you need longer studs but i am sure they provide them wiht there kit
Old Apr 22, 2003 | 01:10 PM
EVIL_AWD's Avatar
Default Re: Turbo B16 guys, How to gain 14whp for 150.00- Tell me if Im right (b18bturbo)
I've been running the Hondata intake manifold heatshield gasket without using longer studs. The stock studs are working fine for me. I also know of quit a few other people who are also using their stock studs with the Hondata heatshield gasket. It might vary depending on application though.
Old Apr 22, 2003 | 01:19 PM
93dx--hatch's Avatar
Default Re: Turbo B16 guys, How to gain 14whp for 150.00- Tell me if Im right (ITR420)
hmm, my friend has some gsr cams that i could get for free.
Would i change my vtec point to 4400rpm?
Old Apr 23, 2003 | 12:20 PM
FredoSP's Avatar
Default Re: Turbo B16 guys, How to gain 14whp for 150.00- Tell me if Im right (93dx--hatch)
up for anymore ideas?
Old Apr 23, 2003 | 03:48 PM
TurboJesse
Guest
Posts: n/a
what about a co2 sprayer for the IC? Im in the process of making one for my car and it is relatively cheap under ~$100
Old Apr 23, 2003 | 04:16 PM
b18cya's Avatar
Default Re: Turbo B16 guys, How to gain 14whp for 150.00- Tell me if Im right (Mpir3)
co2?
Old Apr 23, 2003 | 04:19 PM
FredoSP's Avatar
well i was saying this in reference to what I listed above, not C02...
Old Apr 23, 2003 | 04:33 PM
ricodemus's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93dx--hatch &raquo;</TD></TR><TR><TD CLASS="quote">hmm, my friend has some gsr cams that i could get for free.
Would i change my vtec point to 4400rpm?</TD></TR></TABLE>
I dont see why you would want to. Depending on what motor you have, tuning, and air flow, 4400 may be too low. I know when I put them in my b16, I'm going to leave it at 5k and not worry about it. Starting vtec too low can have a negative effect.
Old Apr 23, 2003 | 04:43 PM
TurboJesse
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FredoSP &raquo;</TD></TR><TR><TD CLASS="quote">well i was saying this in reference to what I listed above, not C02...</TD></TR></TABLE>
My bad...i thought you were looking for any cheap way to gain HP without uping the boost ...I think about this stuff all day, i pretty much set a limit @10psi for now and these are next on my plans to gain hp @10psi
Skunk2 intake manifold
Hondata intake manifold gasket
ITR cams and valvetrain
Co2 Sprayer
Old Apr 25, 2003 | 01:46 AM
FredoSP's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mpir3 &raquo;</TD></TR><TR><TD CLASS="quote">
Co2 Sprayer</TD></TR></TABLE>
looks good to me
bb6guy
Aug 22, 2011 03:49 PM
dbiker207
Jun 16, 2007 02:52 PM
99b18
Dec 27, 2004 06:32 PM
Spooled1.6L
Mar 16, 2004 03:06 PM
