which way to turn the dizzy to retard timing? towards rear of car or front?
Old Apr 21, 2003 | 08:00 PM
ZCHF's Avatar
Default which way to turn the dizzy to retard timing? towards rear of car or front?
i need to retard timing slightly from where it is now. Do i turn it clockwise or counterclockwise? thanks
Old Apr 21, 2003 | 08:02 PM
johnisenglish's Avatar
Default Re: which way to turn the dizzy to retard timing? towards rear of car or front? (ZCHF)
Turn towards the front of the car to retard, and towards the firewall to advance.
But either way, get a timing light and do it right
Old Apr 21, 2003 | 08:04 PM
done's Avatar
do you have a timing gun?
I hope c-speed wont mind me using there site..
full read up right here http://www.c-speedracing.com/h...g.php
this should be what you looking at..
ZCHF's Avatar
Default Re: which way to turn the dizzy to retard timing? towards rear of car or front? (johnisenglish)
thanks , i am running 10 psi and its turned all the way towards the firewall. ill fix that asap! thanks again.
Old Apr 21, 2003 | 08:46 PM
Pengo's Avatar
yea get a timing gun and dont forget to jumper the plug by the ecu otherwise it won't do anything
Old Apr 21, 2003 | 08:55 PM
95c1v1cs1's Avatar
Default Re: which way to turn the dizzy to retard timing? towards rear of car or front? (Pengo)
When moving the distributor: if the idle goes up, you are advancing it. If the idle goes down then it is retarding it.
Old Apr 22, 2003 | 08:50 AM
ZCHF's Avatar
Default Re: which way to turn the dizzy to retard timing? towards rear of car or front? (95c1v1cs1)
thanks for the posts. I will get it fixed asap, it ran like complete crap(bogging when i floored it), so hopefully this will fix the problem. thanks guys
-Darren-
18
Jun 19, 2015 05:55 AM
allnaturalb16
21
Aug 14, 2007 08:57 PM
andyvaj
May 7, 2007 07:34 AM
handa
Apr 11, 2005 10:36 AM
91sihatchback
Jun 29, 2003 05:50 PM
