Rattle at idle
Old Jun 28, 2001 | 10:10 PM
ninjaman's Avatar
New User
Default Rattle at idle
I took my car to a tire shop and when I got it back I hear a light rattle only at idle. I notice it's more pronounced when the A/C is on. It's easier to hear the rattle from inside the car then under the hood, and it sounds like it's coming from underneath - maybe closer to the passenger side.
Any ideas what it could be? I'd like to know soon so I can go back to the tire shop and rage if need be.
Old Jun 29, 2001 | 01:00 PM
ninjaman's Avatar
New User
Default Re: Rattle at idle (ninjaman)
ttt
Old Jul 1, 2001 | 08:17 AM
ALF's Avatar
ALF
Hey, I have the same problem. When idling, it kinda sounds like I have some racing cams....lumpy. Except the "lumps" are rattles. And it only happens when the engine is heated up. When the engine is cold, idle is fine. Anybody have any ideas?!
This sucks...
[Modified by Dozed, 12:18 PM 7/1/2001]
[Modified by Dozed, 12:19 PM 7/1/2001]
Old Jul 1, 2001 | 09:35 AM
LSIntegra94's Avatar
New User
Default Re: Rattle at idle (Dozed)
It's probably the typical heat shield rattle. Annoying, isn't it!?!
Old Jul 1, 2001 | 11:07 AM
ALF's Avatar
ALF
Default Re: Rattle at idle (LSIntegra94)
Definitely not the heat shields. Took 'em all off.
Old Jul 1, 2001 | 11:19 AM
New User
No kidding!?
Old Jul 1, 2001 | 06:12 PM
ninjaman's Avatar
New User
Yeah, I took my heat shield off when I installed my header. If anyone has any ideas, that would be great.
Old Jul 1, 2001 | 09:10 PM
Mr. Choi's Avatar
New User
hey,
my friend also has this problem after i installed his headders.
i also no what causes this rattle at a certian RPM.
first when you or someone else intalled youre headders did they put the gasket from the old exhaust manifold and trasfer it to the new headders??? i pretty sure they didnt, like i did. the gasket im talkin about it located jus before the catalytic converter. if there is no gasket there then the headder and catalytic is hitting eachother and making that sound, nothing really bad, on my friend car, that rattle + leak made his car faster, i dont no why, but thats what he told me. the rattle you are hearing may not be what my friend is hearing, but maybe its the gasket that wasnt placed in the headder when it was installed. hope i was a help.
Old Jul 1, 2001 | 11:25 PM
ninjaman's Avatar
New User
Default Re: Rattle at idle (ChoisVTEC)
I appreciate your help. Unfortunately, I installed the header about six months ago and there was no sound. It just started a couple days ago after I let these fools work on my car. I think I'm going to have to get under it to try to locate the rattle source. I hope nothing's broken
Old Jul 2, 2001 | 12:11 AM
ALF's Avatar
ALF
Hmm...I'd check for loose bolts.
Old Jul 2, 2001 | 08:20 PM
Mr. Choi's Avatar
New User
Hmm...I'd check for loose bolts. [/QUOTE]
Old Jul 2, 2001 | 09:22 PM
crookedletterd's Avatar
New User
ttt
what does that mean??? i see that people just use it to get thier post to the top.... wait a min does it mean "to the top"?? i am a smart one!
EK45VTi
Dec 11, 2007 06:46 PM
Lmgrcivic
Apr 11, 2005 11:13 PM
scn095
Apr 8, 2003 08:41 PM
Blue teg
Nov 27, 2001 01:12 AM
