spot weld remover
Old Apr 21, 2003 | 06:49 AM
baphomet's Avatar
Modified by b3435 at 9:16 PM 6/14/2003
Old Apr 21, 2003 | 07:26 AM
DubbleD's Avatar
Default Re: spot weld remover (b3435)
jus drill them out. thats what i did to remove one of my mounts for my h22a swap.
Old Apr 21, 2003 | 10:33 AM
x2gold's Avatar
Default Re: spot weld remover (DubbleD)
yes, that is a spot-weld removal tool. I bought one for like 16 dollars at a local paint store (automotive paint store that is). The bits are two-sided and work well as long as they don't get caught up. Replacement bits are roughly 16 dollars for three. One should be all you need to remove the rad support. This tool is well worth it's weight in gold. It works awesome.
Old Apr 21, 2003 | 01:30 PM
martini's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DubbleD &raquo;</TD></TR><TR><TD CLASS="quote">jus drill them out. thats what i did to remove one of my mounts for my h22a swap. </TD></TR></TABLE>
drilling them out is not the best way to go about it. I drilled out my steering colum support, and then took an air chisel to seperate the two pieces. I would most definitely use the spot weld remover if I had one available.
Old Apr 21, 2003 | 01:51 PM
BigMoose's Avatar
Default Re: spot weld remover (martini)
I ditto the comments above. That tool won't tear the snot out of the two plies of steel so that when you reweld in a new part things aren't distorted as heck. I like to only drill thru one ply, and have the hole in the material that stays behind. The new part has no holes so then I just TIG in the hole to put a replacement sheet metal part in..... thats for body repairs.
Regards,
BigMoose
tooann
Honda Civic (2006 - 2015)
Apr 10, 2008 01:42 PM
S2KILLA
Honda S2000
Mar 7, 2007 05:52 AM
[Eg.6]LiLbOy916
Oct 28, 2006 09:23 AM
Honda_18
25
Dec 5, 2004 02:38 PM
AL ASPIRATED
May 11, 2004 05:50 AM
