fuel pressure too high...CODE 43
Old Apr 21, 2003 | 05:48 AM
specie's Avatar
Default fuel pressure too high...CODE 43
I'm getting a fuel system code on my '95 Integra LS. My fuel system is stock besides a Walbro fuel pump. I'm getting about 46-48psi at idle and it stays there when I remove the vacuum hose from the fpr. I've tried 3 fpr and all gave the same results. I was getting about 44psi before I removed my cruise control and airbag system (put in a momo wheel). It wasn't giving a code before the wheel install. I think it may have just been a coincidence though.
From my understanding, it doesn't matter if the fuel pump is flowing too much, the FPR controls the pressure and keeps it at normal level. I have no idea how to diagnose this. The only thing I could think of was replacing the fpr but I tried 3 of them and none gave different results. I should be at 40-42psi, correct? Anyone have this problem before? If so, please give me some ideas on this. Thanks.
Old Apr 21, 2003 | 09:45 AM
dwn-shift's Avatar
Default Re: fuel pressure too high...CODE 43 (specie)
My lude was getting a CEL 43 the other day, it has something to do with the o2 sensor i think.
Old Apr 21, 2003 | 10:29 AM
quik2kSi's Avatar
is it a too rich too lean? i through that in my Si every once in while ever since i raised my fuel press. gay *** OBD II. all i do is disconect the bateery for a few and it goes away
Old Apr 21, 2003 | 04:27 PM
specie's Avatar
The fuel pressure is too high, so it's running rich, very rich.
Old Apr 21, 2003 | 04:29 PM
psi420's Avatar
So get an adjustable FPR and turn it down.
Old Apr 21, 2003 | 07:04 PM
specie's Avatar
Default Re: fuel pressure too high...CODE 43 (psi420)
Yes, I guess it's time to put on the B&M I have laying around. Thanks.
http://www.theoldone.com/articles/regulator/
Jahmani
Nov 9, 2018 03:53 PM
91 luder
Aug 28, 2012 04:16 PM
-.1234P312.-^EK_SI^
Sep 8, 2008 07:24 PM
nv707
Oct 7, 2007 06:11 PM
blackcracker
Oct 25, 2002 06:13 PM
