Same problems with the AEM FPR w/ Videos now!
I installed it once again this time but it still continues to act up.
Symtoms:
-B&M fpr gauge reads 57-60 pressure all over the place. Inconsistent.
-Pressure reading same with and without the hose.
-Tuning the fpr does nothing.
-Odd sounds coming from the fuel lines.
Now I was armed with a camera and have some short clips:
1) Key on (II), making some weird sounds from the fuel lines. Filming the fuel pump.
http://www.we-todd-did-racing....3D%3D
2)More noise coming from under the car.
3)Sound is very obvious when heard under the car. Obviously something to do with the fuel.
4)The wack reading with the vacuum hose ON:
5)The wack reading with the vacuum hose OFF:
Hopefully someone can help. Probably going to head over to AEM tommorow and see what they think.
Modified by B2FiNiTY at 1:47 AM 4/21/2003
Symtoms:
did you try a diff gauge? they crap out,i just needed to buy a new one last week becuase it was reading all kinds of retarded pressures, they flucuate too , min new one does too , they are just crap imo .
my old one burned at the expo
The gauge works perfectly fine with the stock FPR.
~50psi with the vacuum hose off and ~40psi with the vacuum hose on.
I am going to get it "professionally" installed today and see what happens.
professionally installed ? dont bother, they prob wont do anthing diff.
take the fpr apaprt and see if the diaphram is seated correctly.
which fitting do you have in ? do you have a bigger fuel pump?
.15? is that the smallest one ? if not i would put the smallest one in and try that ,
how does the car run? and you ever get it on the dyno ? it might just be acting retarded and no effects.
