AEM FPR. Static and base pressure.
Old Feb 2, 2004 | 03:36 PM
5thgencivic's Avatar
Default AEM FPR. Static and base pressure.
I searched every post I could find about fuel pressure and the aem fpr in forced induction Anyway, when I disconnect the vacuum line from my aem fpr the fuel pressure stays the same! It's supposed to go up isn't it? What would cause this? The fuel pressure gauge is a jegs mounted right before the fuel rail and vacuum is coming straight off the mani with no t's... Thanks.
Nate
Old Feb 2, 2004 | 04:47 PM
Sonny's Avatar
Default Re: AEM FPR. Static and base pressure. (5thgencivic)
It sounds like you have the adjustment screw (on the top) backed all the way out.
Sonny
Old Feb 2, 2004 | 05:15 PM
Default Re: AEM FPR. Static and base pressure. (Sonny)
It's out, but I don't think it's all the way out... fuel pressure is set at ~40psi. Also I checked the diaphram and it looks fine.
Old Feb 2, 2004 | 09:05 PM
I'll probably just end up going back to the stock regulator. anybody else have any input?
Old Feb 2, 2004 | 10:42 PM
Silverbeast's Avatar
My aeromotive has never failed me. AEM should be fine, check those lines one more time.
Old Feb 3, 2004 | 07:11 AM
Rtype16's Avatar
Default Re: (Silverbeast)
Never had a problem with the AEM. You may want to check the nipple and make sure it is drilled all the way through.
Old Feb 3, 2004 | 07:20 AM
Default Re: (Rtype16)
It's getting vacuum, but I'm stumped. Would the size of the drain back fitting have anything to do with it? thanks.
Old Feb 3, 2004 | 08:20 AM
Andrea's Avatar
Default Re: (5thgencivic)
Unless you need to get more fuel out of your injectors stick with the OEM regulator, or you have 900cc+ injectors (turn the base fuel pressure up to help idle/off-boost drivability).
Old Feb 3, 2004 | 08:45 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rtype16 &raquo;</TD></TR><TR><TD CLASS="quote">Never had a problem with the AEM. You may want to check the nipple and make sure it is drilled all the way through.</TD></TR></TABLE>
Your right. The fricken damn nipple was plugged this whole time!! I bought it used and didn't even think about checking it. That would explain the bogging. I drilled it out and there was some kind of pink crap in there... thanks.
Nate
Old Feb 3, 2004 | 12:37 PM
Rtype16's Avatar
It was red loctite most likely.
Old Feb 3, 2004 | 01:48 PM
Hopefully it hasn't been running too lean.. amazing how smooth the car is again Lesson learned.
LBR92DA-T
Dec 25, 2003 02:46 AM
SIReg9
Oct 1, 2003 12:42 PM
snake01
May 31, 2002 12:54 PM
Malice
Mar 31, 2002 04:48 PM
