advance timing how to?? is it easy to do?
damn i took off the whole distributor but don't know which part i need to move, this **** drive me nut,i did a search on the web but it confuse me even more damn
undo the 3 bolts and rotate toward the firewall... I hope your using a timing gun
also you have must jump the ECU or else it will compensate for the change
take out your radio and change pocket, theres a plug, 2 wires, the plug is blue...jump that plug thats your service connector....then adjust the distributor by loosening the 3 bolts, ..and using a timing gun is also very useful...if you do not jump the service connector the ECU will compensate and not advance it..peace
no...you dont touch the cap, theres three 12mm bolts that attach the Entire Distributor to the cylinder head, those are the ones you loosen..peace
taguchi09
Jun 11, 2011 04:52 PM
