is 500whp achievable with stock head ???
Old Apr 20, 2003 | 03:19 PM
Cyber ITR's Avatar
Default is 500whp achievable with stock head ???
my setup :
b18c1 block , JE 9:1 (81.5mm) , built bottom end , stock head , hks cam gears
t3/60-1 turbo , JG manifold , overbored throttle body
standalone computer
Old Apr 20, 2003 | 03:29 PM
Dancing is Forbidden's Avatar
Default Re: is 500whp achievable with stock head ??? (SEX DR)
Will that turbo even make that much hp?
Old Apr 20, 2003 | 03:32 PM
Cyber ITR's Avatar
Default Re: is 500whp achievable with stock head ??? (EF9_SiR)
yarp
Old Apr 20, 2003 | 03:33 PM
InfamousRS's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EF9_SiR &raquo;</TD></TR><TR><TD CLASS="quote">Will that turbo even make that much hp?</TD></TR></TABLE>
yup
https://honda-tech.com/zerothread?id=480009
Old Apr 20, 2003 | 03:41 PM
BrokenVtec's Avatar
Default Re: is 500whp achievable with stock head ??? (InfamousRS)
lol you posted before i could!! lol
Old Apr 20, 2003 | 03:50 PM
Cyber ITR's Avatar
Default Re: is 500whp achievable with stock head ??? (BrokenVtec)
so yes or no ??
Old Apr 20, 2003 | 03:52 PM
******* beautiful.
Old Apr 20, 2003 | 04:35 PM
turbotypeR@SPEC's Avatar
25 Year Member
si!
Old Apr 20, 2003 | 04:39 PM
DIRep972's Avatar
Smarter than you
your gonna want to do at least valvesprings and retainers. At the boost level and rpm's your gonna need to run to achieve 500whp those springs are definitly gonna need to be beefed up. Other then that, a mostly stock head will get the job done.
Old Apr 20, 2003 | 04:50 PM
Tinker219's Avatar
Default Re: is 500whp achievable with stock head ??? (IRepD)
what about LS(B1) head? Of course I will be running valve springs/retainers.
Old Apr 20, 2003 | 04:54 PM
Cyber ITR's Avatar
up up
Old Apr 20, 2003 | 05:20 PM
T3's Avatar
T3
Thats kew...I dont needa get camshafts now...Saved 300$
Old Apr 20, 2003 | 05:24 PM
DIRep972's Avatar
Smarter than you
Default Re: is 500whp achievable with stock head ??? (Tinker219)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tinker219 &raquo;</TD></TR><TR><TD CLASS="quote">what about LS(B1) head? Of course I will be running valve springs/retainers.</TD></TR></TABLE>
to make 500 out of an LS head you are definitly going to need cams. oversized valves wouldn't hurt either. vavlesprings/retainers too. the right sized turbo is really the trick though.
Old Apr 20, 2003 | 05:38 PM
93LSivic's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IRepD &raquo;</TD></TR><TR><TD CLASS="quote">
to make 500 out of an LS head you are definitly going to need cams. oversized valves wouldn't hurt either. vavlesprings/retainers too. the right sized turbo is really the trick though. </TD></TR></TABLE>
Yup. Chris knows. Thats my problem now, I need cams to hit that 500 whp mark. LS head doesnt flow all that good--it would help to have the ports worked on.
Old Apr 20, 2003 | 08:29 PM
InfamousRS's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BrokenVtec &raquo;</TD></TR><TR><TD CLASS="quote">lol you posted before i could!! lol </TD></TR></TABLE>
hehe...sorry
Old Apr 21, 2003 | 02:05 AM
Cyber ITR's Avatar
can i get away with stock head if i wanna run 1bar , until i can afford for retainers and springs ?
Old Apr 21, 2003 | 12:31 PM
Cyber ITR's Avatar
Old Apr 21, 2003 | 12:41 PM
DIRep972's Avatar
Smarter than you
yeh plenty of people run 1bar on stock springs/retainers. after 1bar is the point where most people reccomend upgrading, or for revving higher.
Old Apr 21, 2003 | 08:13 PM
Cyber ITR's Avatar
thanks man
93b20z
Feb 3, 2011 04:12 AM
92LSVTEC
Apr 7, 2007 11:06 AM
aznegg
Mar 5, 2007 05:49 PM
gelok
Feb 16, 2004 08:13 AM
bigTom
Jul 26, 2001 11:08 AM
