is 500whp achievable with stock head ???
my setup :
b18c1 block , JE 9:1 (81.5mm) , built bottom end , stock head , hks cam gears
t3/60-1 turbo , JG manifold , overbored throttle body
standalone computer
standalone computer
Re: is 500whp achievable with stock head ??? (EF9_SiR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EF9_SiR »</TD></TR><TR><TD CLASS="quote">Will that turbo even make that much hp?</TD></TR></TABLE>
yup
https://honda-tech.com/zerothread?id=480009
yup
Smarter than you
Re: is 500whp achievable with stock head ??? (SEX DR)
your gonna want to do at least valvesprings and retainers. At the boost level and rpm's your gonna need to run to achieve 500whp those springs are definitly gonna need to be beefed up. Other then that, a mostly stock head will get the job done.
Smarter than you
Re: is 500whp achievable with stock head ??? (Tinker219)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tinker219 »</TD></TR><TR><TD CLASS="quote">what about LS(B1) head? Of course I will be running valve springs/retainers.</TD></TR></TABLE>
to make 500 out of an LS head you are definitly going to need cams. oversized valves wouldn't hurt either. vavlesprings/retainers too. the right sized turbo is really the trick though.
Re: is 500whp achievable with stock head ??? (IRepD)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IRepD »</TD></TR><TR><TD CLASS="quote">
to make 500 out of an LS head you are definitly going to need cams. oversized valves wouldn't hurt either. vavlesprings/retainers too. the right sized turbo is really the trick though. </TD></TR></TABLE>
Yup. Chris knows. Thats my problem now, I need cams to hit that 500 whp mark. LS head doesnt flow all that good--it would help to have the ports worked on.
Re: is 500whp achievable with stock head ??? (BrokenVtec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BrokenVtec »</TD></TR><TR><TD CLASS="quote">lol you posted before i could!! lol </TD></TR></TABLE>
hehe...sorry
hehe...sorry
Re: is 500whp achievable with stock head ??? (InfamousRS)
can i get away with stock head if i wanna run 1bar , until i can afford for retainers and springs ?
Smarter than you
yeh plenty of people run 1bar on stock springs/retainers. after 1bar is the point where most people reccomend upgrading, or for revving higher.
gelok
02-16-2004 08:13 AM
