Yunisden R specs
Old Jun 28, 2001 | 10:16 AM
Yunisden R's Avatar
New User
Default Yunisden R specs
OK here's the setup
1997 Acura Integra R #58
ENGINE
Code: DC2R B18c5
Type: Inline-Four, Aluminum Block and Head
Total Displacement: 18??cc ???mm Bore x ???mm stroke
Valvetrain: Dual overhead camshafts, four valve per cylinder
Variable Valve Timing Electronic Control
Compression Ratio: 13 to 1 (9,600rpm)
ENGINE MODS
Custom JE Forged Pistons
Custom Crower rods
Custom Crankshaft Fullcounter
MCA Stage 6 Headwork
JUN Stage 3 Camshafts IN/EX
JUN Titanium Retainer
JUN Dual High Rev Valve Springs
AEM Cam Sprockets
AEM Power Pulley Kit
AEM Polished Fuel Rail
Custom 3 angle valvejob
Mugen Head Gasket
Haltech E6K Management
ESSEX Fuel Regulator
RC 370cc Injectors
Oversize Front Mount External Oil Cooler
MSD 6A
MSD Blaster 3 Coil
MSD Magnetic pulse stabilizer
Magnecor 8.5mm Wires
Larger VTEC solenoid
Modified Thermostat
Modified Oil Pump
INTAKE-EXHAUST
Custom Updraft Individual Throttle Bodies
(?? mm) & TWM velocity stacks (?? mm)
Custom Filter and Airbox
HiTech custom lightweight stainless steel
DRAG/Road Race Header & Exhaust 16 lbs
Exedy race flywheel and race clutch
stock Type R gearing(new set)
SUSPENSION
Mugen front and rear Sway Bar
Mugen N1 is on the way
Eibach 800 lbs/in front
Eibach 1200 lbs/in Rear
Z-speed camber kit and custom rear
OUTSIDE
Custom Carbon Fiber hood (modified to fit ITB)
INSIDE
Fully gutted
Sparco Rev Race Seat w/ aluminum Sparco Brackets
Reolated Optima Battery(Red)
NHRA Battery Box
Moroso Cutoff Switch
Autometer Exhaust Gas temperature
Autometer Oil Pressure
Autometer Oil Temperature
RAZO Race Pedals
FUEL
VP C14 Leaded Racing Fuel
PLANNING MODS
Rims(no clue which one I want)
Brembo Brakes and slotted rotors( same as the Real time setup)
Cross drilled rear
6 point chrommoly Road cage
16g.fuel cell
Tires
Mugen oil pan
Sparco suit, gloves, shoes, and a steering wheel
Michael (MCA Motorsports)
Ben (AEBS)
Troy (Group5 Motorsports)
Mark (VP Racing Fuel Southeast)
Jon (HiTech Exhaust)
I AM LOOKING FOR SOME SPONSORS
Road racing Only
FIRST TEST RUN : Around September 2001
[Modified by Yunisden R, 10:34 PM 6/29/2001]
Old Jun 28, 2001 | 10:19 AM
Albino Dragon's Avatar
Default Re: Yunisden R specs (Yunisden R)
INSIDE
I think you meant outside on this one
Looks like a very awesome setup
VaporTrail's Avatar
New User
hmm, impressive setup! Perhaps you should come out to the Central FL ITR meet here in Tampa? I'll be hosting a dyno day. HP numbers are always a good thing to have for potential sponsors. Just a thought.
Old Jun 28, 2001 | 10:36 AM
Big Phat R's Avatar
What happened to you? You've been gone for like a year....I was wondering what was up. It's about time you had some numbers though.
Old Jun 28, 2001 | 10:37 AM
Yellow Dragon's Avatar
Sounds good. Lets see some pics now.
Old Jun 28, 2001 | 10:47 AM
Yunisden R's Avatar
New User
Default Re: Yunisden R specs (Yellow Dragon)
I have no clue how to post the pics
Old Jun 28, 2001 | 10:51 AM
Do you have the pics on a host website? Photopoint, etc?
If so, then {img} your host address for the pic .com here {/img}
Instead of {} use [ ]
Make sense?? If not, e-mail Yoshi the pics. Yoshi loves pics. haha.
Old Jun 28, 2001 | 10:52 AM
magic hat #9's Avatar
as vin diesel said in fast n furious, "not a bad way to spend $10,000."
Old Jun 28, 2001 | 11:00 AM
Yunisden R's Avatar
New User
Default Re: Yunisden R specs (monkey_truckR)
I wish it was $10,000. That's not even enough for parts in the motor alone.
_________
01 F150 supercrew 5.4
Old Jun 28, 2001 | 12:09 PM
Hooch'n's Avatar
Sweeeet!
Old Jun 28, 2001 | 12:19 PM
Warren's Avatar
Wrong-Way Wang
Spending the money in the wrong place so far, get a cage, then worry about going faster.
btw - 10 point cage? That's not legal in any sanctioning bodies that the Type R currently runs in. Are you SURE it's a 10 point?
Warren
Old Jun 28, 2001 | 12:29 PM
Yunisden R's Avatar
New User
Default Re: Yunisden R specs (Warren)
Yea is a 10 point chromoly roll cage. Going to get it within the next 2 weeks, will post pics.
I don't think I am spending the money in the wrong place. I got most the the suspension I need, all I need is some serious brake calipers, tires and I will be set. The cage ani't sh*t and is not going to cost much anyway.
What I need to do is to learn how to control this beast.
_______
01 F150 Supercrew 5.4
Ready to tow to Cali end of this year
Old Jun 28, 2001 | 01:08 PM
TRM04's Avatar
Hey Dennis! It's Ahad. Glad to see this project is almost done! Can't wait to see what it does. IM me sometime foo!
Old Jun 28, 2001 | 01:22 PM
Warren's Avatar
Wrong-Way Wang
Is there any reason why you are getting a chromoly cage? If it isn't heat treated properly after welding, they crack, so it really drives up the price of the cage. Mild steel is plenty good for what we do.
What series are you planning on racing this in?
Warren
Old Jun 28, 2001 | 01:46 PM
Big Phat R's Avatar
Too bad it won't be ready for the EXPO. I want to see this car.
Dennis you posted pics of this car before when you just got the ITB's.....?
[Modified by Big Phat R, 3:49 PM 6/28/2001]
Old Jun 28, 2001 | 02:46 PM
SamB's Avatar
New User
Default Re: Yunisden R specs (Big Phat R)
Wow, thats quite a list
Old Jun 29, 2001 | 01:32 PM
Yunisden R's Avatar
New User
Sup Big Phat R
Where's the Expo?
Yea I posted the pics when I just got the ITB
For the roll cage is a 6 point chromoly. Not a 10 point, my mistake. Was thinking about my bro race car.
__________
01 F150 5.4 supercrew
Daily driven
97 BMW 4 dr. M3
15,000 miles PERFECT condition
(For sale)
Old Jun 29, 2001 | 02:01 PM
Big Phat R's Avatar
ButtonWillow Raceway July 21-22 California.
Over 50 Rs are showing up including mine from Canada. Also a NSX club meet.
sean-sports
Jun 1, 2007 01:30 PM
underpressure02
Oct 22, 2002 04:08 PM
underpressure02
Oct 10, 2002 10:16 AM
Alaskan98ITR406
Jun 25, 2002 11:13 PM
CWITR
Nov 5, 2001 06:25 PM
