is shorter or longer gears better when running nitrous
Old Apr 20, 2003 | 08:03 AM
krazykid's Avatar
Default is shorter or longer gears better when running nitrous
which is better when running like a 60 shot
Modified by B20Demon at 10:50 PM 4/20/2003
Old Apr 20, 2003 | 01:49 PM
krazykid's Avatar
Default Re: is shorter or longer gears better when running nitrous (B20Demon)
ttt
Old Apr 20, 2003 | 02:37 PM
simple4012's Avatar
New User
IMHO use the shortest possible gearing you can afford. acceleration is mathematical multiplied by the gear ratios....why go longer?
Old Apr 20, 2003 | 02:55 PM
tmkpres's Avatar
Default Re: is shorter or longer gears better when running nitrous (simple4012)
nitrous is like boost it needs more rpms I used the ls tranny ran better than the si tranny I had.
Old Apr 20, 2003 | 03:59 PM
Kataku2K3's Avatar
Default Re: is shorter or longer gears better when running nitrous (tmkpres)
Nitrous is NOT just like boost... Especially on a stock bottom end motor you will destroy your rings with the addtional pressure... Boosted motors (turbo/supercharged) generate power by adding more air to the mix... Nitrous on the other hand is an oxidizer which still burns a lot hotter than any F/I motor under high boost... I personally would go with shorter gears if possible... AGAIN, you don't want to go too short as you will just spin... I would go with a basically stock gearing... On an N20 GSR motor I would stick with the GSR tranny... I wouldn't put a straight LS tranny on any B series motor making less that 600whp... It hurt my friend's daily driven GSR turbo EK's time and he was making 506whp... Just my $0.02 on the situation but you can do whatever you want... Peace
speedycrx
Nov 23, 2007 07:41 AM
MARVNVRAM
Apr 18, 2007 12:41 PM
typesguy
Feb 26, 2004 01:58 PM
whatVTEC
Jun 16, 2003 03:48 PM
shawnc21
Feb 25, 2003 06:05 PM
