what ratio fmu with 450cc dsm injectors, I did a search, nothing!
Old Apr 19, 2003 | 10:24 PM
hybridb18's Avatar
Default what ratio fmu with 450cc dsm injectors, I did a search, nothing!
what ratio fmu should i use on a turbo ls running like 12-13 psi, with 450cc dsm injectors and an afc. i have a 12-1 right now, just like to know around what range i should get. it will be tuned and everything. and no, im not doing an afc hack, i would rather just run the fmu
Old Apr 19, 2003 | 11:10 PM
hybridb18's Avatar
Default Re: what ratio fmu with 450cc dsm injectors, I did a search, nothing! (hybridb18)
Old Apr 20, 2003 | 12:11 AM
Smashback's Avatar
Seems like a silly way to do it, but I'm pretty sure that a 6:1 would do the trick.
Old Apr 20, 2003 | 07:44 AM
E-Rok's Avatar
EPIC TUNING
Default Re: what ratio fmu with 450cc dsm injectors, I did a search, nothing! (Hatchblack)
the car will idle/run terrible with an FMU and 450's. get an Uberchip for the same price as an FMU.
Old Apr 20, 2003 | 10:10 AM
hybridb18's Avatar
hoiw would that be a silly way to do it, i would run the 450's and fmu, and use the safc to tune it out, seems easier than an afc hack where u gotta mess with the ignition timing
Old Apr 20, 2003 | 10:28 AM
dfoxengr's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hybridb18 &raquo;</TD></TR><TR><TD CLASS="quote">hoiw would that be a silly way to do it, i would run the 450's and fmu, and use the safc to tune it out, seems easier than an afc hack where u gotta mess with the ignition timing</TD></TR></TABLE>
yeah it would be fine with that setup and 12:1
Old Apr 20, 2003 | 11:38 AM
shermanyang's Avatar
isn't this the same thing as a hack??!!
Old Apr 20, 2003 | 11:40 AM
dfoxengr's Avatar
Default Re: what ratio fmu with 450cc dsm injectors, I did a search, nothing! (shermanyang)
no you use no FMU with the hack
Old Apr 20, 2003 | 12:08 PM
TeStUdO's Avatar
the whole reason you get 450 injectors is so you can run without the fmu isnt it?? so they will supply enough fuel on their own then use an vafc or something to piggyback it??
Old Apr 20, 2003 | 12:38 PM
hybridb18's Avatar
Default Re: (00si5)
so ur saying i still would need to run the 12-1 fmu with the 450cc? i was thinking like 6-1 or 8-1.. I think the 12-1 is overkill on 450cc
Old Apr 20, 2003 | 12:42 PM
hybridb18's Avatar
Default Re: what ratio fmu with 450cc dsm injectors, I did a search, nothing! (hybridvteceg)
http://www.homemadeturbo.com/f...ard=6
anyone who doesnt know about the 450cc dsm's and the afc hack theres some good info here.
Old Apr 23, 2003 | 05:45 PM
p0gi's Avatar
I think a 4:1 would be right. I use a 4:1 with my 370s and add fuel with my e-manage. A 6:1 should be right for 370s
Old Apr 23, 2003 | 05:52 PM
twkdCD595's Avatar
Default Re: what ratio fmu with 450cc dsm injectors, I did a search, nothing! (p0gi)
What is it with people and these things... the whole reason for the hack is to elimate the high pressure raising rate regulator (FMU) and to tune it using some sort of fuel controler.
Old Apr 23, 2003 | 06:16 PM
p0gi's Avatar
Default Re: what ratio fmu with 450cc dsm injectors, I did a search, nothing! (twkdCD595)
Did you read that he said he wasnt using the hack?
Old Apr 23, 2003 | 06:18 PM
r4adkshn1's Avatar
what turbo are u using ? i'm curious.
but yeah try 4 or 6:1 that should get u the fuel. get a high pressure pump if u don't have one.
don't hate, appreciate the RRR.
Modified by r4adkshn1 at 8:01 PM 4/23/2003
Old Apr 23, 2003 | 09:37 PM
twkdCD595's Avatar
your right I should have read more... I just got to fmu and thought about it before finishing.
Old Apr 23, 2003 | 11:48 PM
mey_xanng's Avatar
I say a 6:1
here's how I calculated it 12 * 240 = 2880, 2880 / 450 = 6.1
12 = recomended setting w/ stock injectors, and 240 is injector size, along with 450
another benefit is that the fuel pressures will only be half as high as the 12:1 setup
Old Apr 24, 2003 | 12:19 AM
swlabhot's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by p0gi &raquo;</TD></TR><TR><TD CLASS="quote">Did you read that he said he wasnt using the hack?</TD></TR></TABLE>
If he wasn't using the hack then why is he using 450cc injectors?!?! Theres no need!!
Old Apr 24, 2003 | 04:24 AM
T-RO's Avatar
Wouldnt you be better off using the hack and the 450's with no FMU?
Old Apr 24, 2003 | 07:03 AM
p0gi's Avatar
Default Re: what ratio fmu with 450cc dsm injectors, I did a search, nothing! (swlabhot)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by swlabhot &raquo;</TD></TR><TR><TD CLASS="quote">
If he wasn't using the hack then why is he using 450cc injectors?!?! Theres no need!!</TD></TR></TABLE>
Why dont you read his post where he said " AND NO IM NOT USING THE HACK"
Doesnt anybody read the complete post anymore?
Old Apr 24, 2003 | 08:32 AM
Finest's Avatar
High fuel pressures = bad Mmmmmkay?
AFC hack = enough fuel, stock fuel pressures, everyone happy
But *if* you're so stuck on using the FMU with those 450's, try something higher than 6:1...reason being: you want to be SAFE than sorry! But then again, I don't know how safe you'll be with an FMU in the first place... LOL! It's a new oxymoron!
Old Apr 24, 2003 | 08:45 AM
dfoxengr's Avatar
Default Re: what ratio fmu with 450cc dsm injectors, I did a search, nothing! (98CTRCoupe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98CTRCoupe &raquo;</TD></TR><TR><TD CLASS="quote">High fuel pressures = bad Mmmmmkay?
But *if* you're so stuck on using the FMU with those 450's, try something higher than 6:1...reason being: you want to be SAFE than sorry! But then again, I don't know how safe you'll be with an FMU in the first place... LOL! It's a new oxymoron! </TD></TR></TABLE>
FMUs are always safe...
hybridb18
Apr 21, 2003 10:46 AM
untitled
Mar 19, 2003 06:27 AM
DD_JonnyLee
Feb 20, 2003 11:31 AM
pelotudo
Sep 9, 2002 08:52 PM
KoRE
Jun 25, 2002 08:52 PM
