Code 22 help!!!
Old Apr 19, 2003 | 10:23 PM
JKim0901's Avatar
Default Code 22 help!!!
hello guys I have a problem.....I have a B18c5 with a re-chipped p-28 in my teg. the other day i was running my car pretty hard and the car bogged at about 6k rpm....I checked the code since the CEL is on and it threw a 22
well anyways ever since after that when ever i floor the car v-tec will kick in at 5.5k like its suppose to and then it shuts off (like it feels like the car bogs) and the it reactivates........how do i fix this? what is wrong sorry for the long explanation but i know you guys can helo and Thanks in advance for reading and helping me out
Old Apr 19, 2003 | 10:29 PM
xpracing's Avatar
Default Re: Code 22 help!!! (JKim0901)
I think that code is for the vtec oil pressure switch.
Old Apr 20, 2003 | 12:44 AM
psi420's Avatar
First thing that comes to mind is Oil Pressure.
Old Apr 20, 2003 | 03:44 PM
JKim0901's Avatar
Default Re: (psi420)
yea code 22 is oil pressure but i was wondering what i can do to fix this problem
Old Apr 28, 2003 | 06:32 PM
type Gendy's Avatar
Default Re: (JKim0901)
how'd u make out?
Old Apr 30, 2003 | 08:22 PM
Black_eh2's Avatar
New User
Default Re: (sick hatchem)
me too have same problem
Old May 3, 2003 | 03:57 PM
mrduque's Avatar
Default Re: (SleeperEG6)
I have the same problem too.. I changed all the vtec stuff. both the switch, and the soleniod.. i even changed the housing with the plunger.. none of that stuff worked.. . im gonna open up my head tomorrow, and also check the oil pump. hopefully that fixes the prob..
Old May 3, 2003 | 05:29 PM
type Gendy's Avatar
Default Re: (mrduque)
damn, i ordered the gaskets this week. I was gonna try replacing them adn cleaning the solenoid first. You said that didnt fix your problem? My car also has bad hesistation under 5k rpm? Do you guys have anything like this? I am curious if its related or not. I am tired of reseting my ecu every 2 hrs, only to get an hour of driving out of it. Weird thing is.... i ordered the gaskets to fix a leak, then missed a gear racing a corvette, then got code 22, in that order. I really hope i didnt **** something up.
Old May 3, 2003 | 08:41 PM
type Gendy's Avatar
Why does it seem like there is **** for help on here anymore?? I have been having the same problems with my car for over a month now, and cant get one bit of feasible advice since its not about GF problems or what rims to get.
Old May 3, 2003 | 10:24 PM
honda_power69's Avatar
Well as for your code, its not VTEC related. You are losing oil pressure somehow, try stopping the leak you described first, this could be the source. If your ECU throws a code, it automatically crosses over into limp-home mode, disabling your VTEC and severely limiting your power output. Plain and simple, your VTEC isn't working becuase of an oil pressure problem, your ecu is trying to save your engine. So do some homework, check for leaks, and be sure and check the oil pump. Also, are you running an aftermarket air intake?
Old May 4, 2003 | 10:33 AM
mrduque's Avatar
Default Re: (honda_power69)
i'm running an after market intake.. what does that do?? ne way.. i'm gonna check the oil control orifice today.. i'll keep everyone posted..
Old May 8, 2003 | 12:41 AM
ciRcuitJerk's Avatar
jus f0 dekarayshunZ
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by honda_power69 &raquo;</TD></TR><TR><TD CLASS="quote">Well as for your code, its not VTEC related. You are losing oil pressure somehow, try stopping the leak you described first, this could be the source. If your ECU throws a code, it automatically crosses over into limp-home mode, disabling your VTEC and severely limiting your power output. Plain and simple, your VTEC isn't working becuase of an oil pressure problem, your ecu is trying to save your engine. So do some homework, check for leaks, and be sure and check the oil pump. Also, are you running an aftermarket air intake?</TD></TR></TABLE>not all codes put your car into limp mode btw
ViXoN Hatch94
Nov 28, 2005 01:40 AM
spoonfedGSR
Sep 26, 2003 02:31 PM
typer_801
Mar 19, 2002 07:08 AM
boost killz
Sep 7, 2001 07:01 PM
