install a test pipe ?
Old Apr 19, 2003 | 10:18 PM
wm5holla's Avatar
Default install a test pipe ?
i went to a few shops and asked a test pipe...they all said we wont do it b/c its a 10 grand fine if they do.. a test pipe should a str 8 bolt up only nuts and screws. i should be able to do it inmy drive way.i know i will need to have the muffler welded at a shop
Old Apr 19, 2003 | 10:26 PM
Starrman85's Avatar
Default Re: install a test pipe ? (wm5holla)
what exactly is your question?
my question is why would you want a test pipe on a street car?
Old Apr 21, 2003 | 12:17 PM
wm5holla's Avatar
Default Re: install a test pipe ? (STARRMAN85)
cheaper, more hp,louder
Old Apr 21, 2003 | 12:22 PM
psi420's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by STARRMAN85 &raquo;</TD></TR><TR><TD CLASS="quote">
my question is why would you want a test pipe on a street car?</TD></TR></TABLE>
Cause some people dont give a flying **** what CARB says or does!
We remove them on street driven cars for more power!
Old Apr 21, 2003 | 02:01 PM
dfoxengr's Avatar
Default Re: install a test pipe ? (psi420)
yeah its 6 bolts total...simple
Old Apr 21, 2003 | 02:10 PM
RyanEJ8's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by psi420 &raquo;</TD></TR><TR><TD CLASS="quote">
We remove them on street driven cars for more power!</TD></TR></TABLE>
Especially for those who live in an area like me and don't have to worry about CARB.
Old Apr 21, 2003 | 02:33 PM
gsrvx's Avatar
New User
That's the spirit!!!
Old Apr 21, 2003 | 05:46 PM
Blaze45's Avatar
Brrraaaap!
Default Re: install a test pipe ? (RK)
Sometimes when you take out the stock cat and put in a testpipe you actually lose power. The dyno is on the honda-perf.com board when they dyno tested the B20 it lost a few hp and ft. lbs. of trq.
Blaze
Old Apr 21, 2003 | 08:42 PM
ScottEK's Avatar
Default Re: install a test pipe ? (Blaze45)
You might want to check if you are referring to a gutted cat or a test pipe, because a there is no reason an actual test pipe that is that same diameter all the way through would lower horsepower. A gutted cat with larger chamber on the other hand can obviously cause the exhaust gasses to circulate and possibly back up.
Old Apr 22, 2003 | 10:09 AM
RyanEJ8's Avatar
Default Re: install a test pipe ? (beta13)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by beta13 &raquo;</TD></TR><TR><TD CLASS="quote">You might want to check if you are referring to a gutted cat or a test pipe, because a there is no reason an actual test pipe that is that same diameter all the way through would lower horsepower. A gutted cat with larger chamber on the other hand can obviously cause the exhaust gasses to circulate and possibly back up.</TD></TR></TABLE>
correct. there is no reason a test pipe looses power.
Old Apr 22, 2003 | 10:32 AM
Blaze45's Avatar
Brrraaaap!
Default Re: install a test pipe ? (RyanCivic2000)
Prolly was a gutted cat. Now I have to go and check.
Blaze
Old Apr 25, 2003 | 04:29 PM
wm5holla's Avatar
We remove them on street driven cars for more power!</TD></TR></TABLE> what a CARB?
Old Apr 25, 2003 | 04:32 PM
wm5holla's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by beta13 &raquo;</TD></TR><TR><TD CLASS="quote"> A gutted cat with larger chamber on the other hand can obviously cause the exhaust gasses to circulate and possibly back up.</TD></TR></TABLE> explain? is that a bad thing!
Old Apr 25, 2003 | 04:34 PM
psi420's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wm5holla &raquo;</TD></TR><TR><TD CLASS="quote"> what a CARB?</TD></TR></TABLE>
California Air Resources Board
Smog people
Old Apr 25, 2003 | 10:08 PM
RyanEJ8's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wm5holla &raquo;</TD></TR><TR><TD CLASS="quote"> explain? is that a bad thing!</TD></TR></TABLE>
if you don't realize that exhaust gases backing up into your motor is a bad thing then you have alot of research to do. free flow OUT of the motor is the objective of the exhaust.
Old Apr 26, 2003 | 09:15 AM
ScottEK's Avatar
Exactly, thank you Ryan. Same idea as if you were to have a header that the ports were not matched to your head and the exhaust gases circulated and re-entered the combustion chamber. Your air to fuel ratio would suck, it would run like crap.
Old Apr 26, 2003 | 11:16 AM
crazy eyez killa
Guest
Posts: n/a
HAHAHAHHA
This gets my vote for the stupidest question of the year.
LimaBean
May 14, 2008 09:30 AM
MADBADGER
Honda S2000
25
Nov 29, 2007 04:56 AM
SuicideSlide
10
Sep 23, 2004 05:58 AM
billybong91DA
Mar 20, 2004 10:15 AM
spoolinlude
May 4, 2003 08:18 PM
