Honda S2000 Honda S2000
What Testpipe?
Old Nov 21, 2007 | 04:45 PM
MADBADGER's Avatar
Default What Testpipe?
I'm looking to purchase a testpipe, i have a 70mm exhaust (Invidia) should i stick with the 70mm and get that size as a test pipe? sugggested test pipe brands? anything you can give me, thanks
Old Nov 21, 2007 | 05:33 PM
cmdr430's Avatar
Default Re: What Testpipe? (MADBADGER)
yes get a 70mm
however, please use it for dyno runs or on the track only....
don't pollute the environment w/ everyday use.....
also, if you get caught running one on the street, plan on paying a hefty fine.....
Old Nov 21, 2007 | 05:48 PM
Techno Tonis's Avatar
Default Re: What Testpipe? (cmdr430)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cmdr430 &raquo;</TD></TR><TR><TD CLASS="quote">
also, if you get caught running one on the street, plan on paying a hefty fine.....</TD></TR></TABLE>
not in ohio
Old Nov 21, 2007 | 05:59 PM
MADBADGER's Avatar
Default Re: What Testpipe? (Techno Tonis)
yeah ohio cops are laid back on stuff like this
Old Nov 21, 2007 | 06:19 PM
Import_Fan's Avatar
I mean a test pipe is a test pipe. It's just a freaking pipe. The brand doesn't matter.
Old Nov 21, 2007 | 06:43 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MADBADGER &raquo;</TD></TR><TR><TD CLASS="quote">I'm looking to purchase a testpipe, i have a 70mm exhaust (Invidia) should i stick with the 70mm and get that size as a test pipe? sugggested test pipe brands? anything you can give me, thanks</TD></TR></TABLE>
I personally love the t1r and j's racing ones...but almost any will do
Old Nov 21, 2007 | 07:04 PM
MADBADGER's Avatar
exactly, a pipe is a pipe, i don't like the idea of spending 100$ on a piece of steel, but
Old Nov 21, 2007 | 07:14 PM
s2kdre's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MADBADGER &raquo;</TD></TR><TR><TD CLASS="quote">exactly, a pipe is a pipe, i don't like the idea of spending 100$ on a piece of steel, but</TD></TR></TABLE> cheap skate!
Old Nov 22, 2007 | 10:18 AM
ReddotsS2K's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cmdr430 &raquo;</TD></TR><TR><TD CLASS="quote">yes get a 70mm
i thought that only california was the only state that gave a ****
Old Nov 22, 2007 | 11:10 AM
papa5murf's Avatar
T1R offers a 70mm test pipe.
Old Nov 22, 2007 | 11:13 AM
papa5murf's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Techno Tonis &raquo;</TD></TR><TR><TD CLASS="quote">
not in ohio
Boy are you sadly mistaken. It's actually a FEDERAL law that you can't tamper with emissions equipment (especially removing the cat). The fine is usually impounding of the car + (roughly) $2000. Now weather you get charged with tampering is a complete different issue from state to state.
Old Nov 22, 2007 | 01:22 PM
dc2vu's Avatar
Default Re: What Testpipe? (papa5murf)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by papa5murf &raquo;</TD></TR><TR><TD CLASS="quote">Boy are you sadly mistaken. It's actually a FEDERAL law that you can't tamper with emissions equipment (especially removing the cat). The fine is usually impounding of the car + (roughly) $2000. Now weather you get charged with tampering is a complete different issue from state to state. </TD></TR></TABLE>
Very true, if a shop is caught removing converters and installing test pipes or hollow pipes (tampering with emissions equipment), they're lookin at tens of thousands in fines and many charges.
Old Nov 22, 2007 | 03:51 PM
ReddotsS2K's Avatar
yes it is ILLEGAL, but in some areas it is not inforced as heavily as it is in california and im sure virginia too since all virginia cops are ********.
i had a test pipe but i took it off, not because of emissions....just because everytime i went in reverse i rolled into the smoke and it smalled like ***
Old Nov 22, 2007 | 09:02 PM
I never said it wasn't a federal law that makes it illegal smurf. I was only stating that in ohio, its just a improper equipment charge, which is like $75. Ohio did away with e-check, so the cops are wayyy more layed back on stuff like that now, that could in all honesty care less.
they are cracking down on ricers though like no other
Old Nov 23, 2007 | 05:38 PM
2+2=5's Avatar
Default Re: What Testpipe? (ReddotsS2K)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ReddotsS2K &raquo;</TD></TR><TR><TD CLASS="quote">
i had a test pipe but i took it off, not because of emissions....just because everytime i went in reverse i rolled into the smoke and it smalled like *** </TD></TR></TABLE>
not trying to be an **** but do you know why there's a law againist it in the first place? becuase allt he bad stuff coming out of the pipe is ruin the enviorment, which you, your mom and your son will be living in it.
for the .2589 torque gained at 8700rpm, lay off the pipe
Old Nov 24, 2007 | 10:44 AM
ap1lvr's Avatar
Old Nov 24, 2007 | 12:18 PM
ap1FTW's Avatar
i think invidia actually makes a 70mm test pipe now
Old Nov 24, 2007 | 12:28 PM
GetawayInMoscow's Avatar
Default Re: (ap1FTW)
Hondas burn relatively clean.
A few members of Honda-Tech having test pipes on their cars isn't going to make a noticable impact WHATSOEVER.
**** if every S2000 came test piped it still would barely make a difference.
If you want more power, why not do it? The environment is the worst reason ever to tell someone not to run a test pipe.
Honda-Tech hypocrits and idiots
Old Nov 24, 2007 | 12:40 PM
AlphaKennyWun's Avatar
Default Re: (GetawayInMoscow)
does having that puny resonator on the pipe do anything in terms of sound?
Old Nov 25, 2007 | 11:39 AM
HondaKyle's Avatar
Chicago they dont care! alot of people with turbo cars run open down pipe and never get **** for it .... as long as its not loud
Old Nov 25, 2007 | 11:46 AM
Default Re: (AlphaKennyWun)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AlphaKennyWun &raquo;</TD></TR><TR><TD CLASS="quote">does having that puny resonator on the pipe do anything in terms of sound? </TD></TR></TABLE>
what the hell are you talking about?
Old Nov 25, 2007 | 03:14 PM
papa5murf's Avatar
Maybe a pinch quieter, but nothing else.
papa5murf's Avatar
Default Re: What Testpipe? (HondaKyle)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HondaKyle &raquo;</TD></TR><TR><TD CLASS="quote">Chicago they dont care! alot of people with turbo cars run open down pipe and never get **** for it .... as long as its not loud </TD></TR></TABLE>
Yeah... and open downpipe isn't gonna be quiet.
Old Nov 29, 2007 | 01:36 AM
LumpyTheGrumpyCamshaft's Avatar
some kinda dumb people, running a open cat on the street is very very dumb.
first, most cops won't check.. most cops don't give two *****... but one cop will,
he will check when he sees you have a exhaust... or just check regardless.
it's thousands of dollars out of your pocket so you can have a louder car that attracts more attention from cops and people that steal stereos
smart.
Modified by LumpyTheGrumpyCamshaft at 7:00 AM 11/29/2007
Old Nov 29, 2007 | 03:14 AM
Hugo.'s Avatar
Default Re: What Testpipe? (LumpyTheGrumpyCamshaft)
ive read somewhere and heard on a news interview that cats produce gases that are not even natural into the atmosphere. ive always had the thought of picking the lesser of two evils, unnatural gases or extra dirty exhaust. ive just went with the option that gave me more power. im from Michigan where they are lax on emissions as well.
