Stroker kits
Old Apr 19, 2003 | 08:10 PM
Spoonin's Avatar
Default Stroker kits
What is better, Spoon stroker kits or Eagle stroker kits?
Old Apr 19, 2003 | 08:28 PM
Spoonin's Avatar
Default Re: Stroker kits (Spoonin)
BTW, the reason I am asking is because I was planning on buying a spoon stroker kit from inlinefour.com for a B16 because it gives it 1.8l of disp., 87.2mm stroke (just like a type r), keeps an 81mm bore or optional 81.25, and gives it 11.3 compression! Seems like it could make a B16 into a B18C, but stronger(bottom end wise).
Old Apr 19, 2003 | 09:01 PM
Michael Delaney's Avatar
why not just get a B18C crank (87.2mm stroke), 134 mm custom rods to fit onto the B18C crank (same rod length as b16a rods except they fit on the B18C crank), any forged medium silicon aftermarket piston (balanced) make you like?
that's all the stroker kit is.
why pay the extra "bucks" for the Spoon name? or Toda name?
Old Jul 24, 2003 | 11:29 PM
Spoonin's Avatar
Default Re: Stroker kits (Michael Delaney)
http://www.modacar.com/product...DASTK/
How would this stroker kit compare to a LS/VTEC? Wouldn't it be better for reliability?
Old Jul 25, 2003 | 02:33 AM
eg_type_r93's Avatar
i got a complete usdm itr bottom end, ie crank con rods and pistons for sale if interisted can get pics if you want
email me at eg_type_r93@yahoo.ca
daniel
the spoon stroker kit is the same thing besides, its jdm and the pistons are balanced thats it
Old Jul 25, 2003 | 06:09 PM
Spoonin's Avatar
Default Re: (eg_type_r93)
Already looked that up. I can't use that bottom end. It will work in a B16b which has a 270mm deck but, I am getting a B16a which is 263mm. Inline four said that the pistons would stick about 7mm out of the deck.
Old Jul 25, 2003 | 09:09 PM
All-Motor H22A's Avatar
Default Re: (Spoonin)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Spoonin &raquo;</TD></TR><TR><TD CLASS="quote">Already looked that up. I can't use that bottom end. It will work in a B16b which has a 270mm deck but, I am getting a B16a which is 263mm. Inline four said that the pistons would stick about 7mm out of the deck. </TD></TR></TABLE>
How about the Crower Stroker Kit?
Old Jul 26, 2003 | 05:28 PM
Spoonin's Avatar
Default Re: (All-Motor H22A)
I saw the eagle ones for a better price.
061000rr
Sep 24, 2009 02:08 AM
blk_eg4
12
Aug 23, 2007 09:45 AM
quik sol
Sep 30, 2003 06:44 AM
ek9lau
May 13, 2003 01:58 PM
Gmedalion
Oct 5, 2001 10:11 AM
