Removing ps belt only?
Old Apr 19, 2003 | 12:10 AM
Chris93Si's Avatar
Default Removing ps belt only?
I'm thinking about removing just my ps belt to see whether or not I can live w/o it. Any ill effects to just removing the belt? In theory I'm planning on taking the belt off for a few weeks and either removing the system/looping the lines or putting the belt back on but chances are I'll end up running just w/o the belt for six months. Can this damage my car? TIA
Old Apr 19, 2003 | 01:34 AM
thaiphob's Avatar
Nikon!!!
Default Re: Removing ps belt only? (Chris93Si)
just leave it the way it is. if you take it off you'll want it back on.
Old Apr 19, 2003 | 01:46 AM
SoCal ITR's Avatar
Default Re: Removing ps belt only? (thaiphob)
Unless you loop the lines, steering will be a pain.
Old Apr 19, 2003 | 02:01 AM
SpoonEK2's Avatar
Default Re: Removing ps belt only? (SoCal ITR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SoCal ITR &raquo;</TD></TR><TR><TD CLASS="quote">Unless you loop the lines, steering will be a pain.</TD></TR></TABLE>
I can confirm this....
Old Apr 19, 2003 | 01:27 PM
ActiveAero's Avatar
Paragraph Alert
25 Year Member
Community Builder
Community Influencer
I haven't had my power steering belt on for over a year. It is really only a pain at super low speeds (less than 2-3mph I would say). If you have crappy tires, as in soft sidewalls, the effort will be even more, but since I don't I'm not bothered by it. People that drive my car complain and when someone two drivered my car at an auto-x event they were shocked I didn't put it back on but I've gotten use to it so I don't notice. I say got for it. Its not like it is hard to put back on.
Old Apr 19, 2003 | 01:33 PM
RTW DC2R's Avatar
Default Re: Removing ps belt only? (ActiveAero)
hardly notice a difference while driving over 5mph. under 5mph such as when pulling into and out of parking spaces or drive ways, you have to muscle it somewhat. once i removed the ps belt, believe it or not you will notice a difference in the way the car feels, better response and a little more on the butt dyno. since then i removed my whole ps system and wouldnt think of putting it back in.
Chris93Si's Avatar
Why would I need to loop the lines if the pump is still in place? I only removed the belt not the pump.
Car feels like a car w/o ps, so far I'm enjoying it
Old Apr 19, 2003 | 01:34 PM
Chris93Si's Avatar
Default Re: Removing ps belt only? (CACK ***!)
Converge
Old Apr 19, 2003 | 01:39 PM
Reid's Avatar
Global Moderator
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thaiphob &raquo;</TD></TR><TR><TD CLASS="quote">just leave it the way it is. if you take it off you'll want it back on.</TD></TR></TABLE>
If you take it off, you'll want to loop the P/S rack and throw the P/S system away.
Old Apr 19, 2003 | 02:31 PM
Chris93Si's Avatar
Default Re: Removing ps belt only? (Reid)
Is throwing it away part of the process? hehehe Thanks for the help guys.
Old Apr 19, 2003 | 09:43 PM
Padawan's Avatar
Darth ModerVader
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Reid &raquo;</TD></TR><TR><TD CLASS="quote">If you take it off, you'll want to loop the P/S rack and throw the P/S system away.</TD></TR></TABLE>
My thoughts exactly, except my system is still sitting in my garage (what can I say, I save everything ).
Old Apr 20, 2003 | 06:21 AM
00MRSi's Avatar
Default Re: Removing ps belt only? (Padawan)
Can anyone give some info on who to loop the p/s system, or where to find the info?
Old Apr 20, 2003 | 07:37 AM
Padawan's Avatar
Darth ModerVader
Default Re: Removing ps belt only? (00MRSi)
https://honda-tech.com/zerothread?id=184202
https://honda-tech.com/zerothread?id=462824
There are obviously a number of ways to accomplish this. I took the less complex/expensive route and simply installed a fitting at the rack and formed a reasonably sized loop with a T in the middle that could be capped-off after filling. I left some space in the loop (i.e. didn't fill the rack/loop completely to the top) to allow for some expansion and comprssion. End result was exactly what I wanted, and best of all, the total cost was only around $15.
Modified by Padawan at 1:34 PM 4/20/2003
Modified by Padawan at 4:20 PM 4/20/2003
Old Apr 20, 2003 | 08:46 AM
Philly_NBP_R's Avatar
If your'e gonna take off the belt, at least drain the fluid from the system - it will make it ALOT easier to turn and park. Obviously putting in a loop / breather system is the best solution, but some of us might want to leave the system in place for street or winter driving...
Old Apr 20, 2003 | 09:08 AM
Turtle's Avatar
Default Re: Removing ps belt only? (98mrgs-r)
someone should re-post that thread on power steering removal...I may later...but I'm out the door...NICE weather in da burgh right now!
highneo
Jan 4, 2009 07:56 AM
gsr1289
Jun 18, 2008 11:50 AM
turbotime
May 27, 2006 04:54 PM
jdmztrane
Jan 5, 2006 08:21 AM
andrewasf77
Jul 8, 2003 12:14 PM
