Old gas, need to syphon.
Old Apr 18, 2003 | 07:24 AM
liquid51's Avatar
Default Old gas, need to syphon.
I just had an idea and was wondering if it would work. My car's been sitting for around 8 months and I need to syphon the gas. Could I just run the end of the fuel line into the gas can and turn the key, letting the fuel pump prime and pump all the gas out itself? My engine isn't in yet so I figured this might be easier at this point. I know it would be almost as easy to syphon it from the fill, but I'm just curious.
Old Apr 18, 2003 | 08:32 AM
Stew Pidasso's Avatar
Default Re: Old gas, need to syphon. (liquid51)
I need to know this also.../\/\
Old Apr 18, 2003 | 08:52 AM
JimBlake's Avatar
Default Re: Old gas, need to syphon. (Stew Pidasso)
As long as you aren't stirring up 8-month-old crud & plugging up your pickup strainer, then yes. It sounds pretty easy to take the fuel line off from the filter & stick it into a gas can... If you run the fuel pump by jumpering something with a screwdriver, just don't set the gas can on fire.
Old Apr 18, 2003 | 08:57 AM
GZERO's Avatar
why don't you drain the tank with the drain plug?
Old Oct 30, 2003 | 11:33 AM
liquid51's Avatar
Default Re: Old gas, need to syphon. (GZERO)
LOL
yeah, this is old as hell. But that's what I did. haha.
Old Oct 31, 2003 | 06:01 PM
Cynical 1's Avatar
Should have used Sta-Bil...
Old Nov 1, 2003 | 11:18 AM
GTurbo00's Avatar
Default Re: Old gas, need to syphon. (Revolveu2)
Isn't using Sta-Bil the safest way?!? I need to know this as well.
Old Nov 1, 2003 | 11:52 AM
spaceman's Avatar
my car was sitting in my garage for 6-7 months until i got the motor all hooked up and it started up just fine..i dont think you have to do all that..maybe put some kind of octane booster in before you start it if you want..
Old Nov 1, 2003 | 12:26 PM
Kamin's Avatar
Default Re: Old gas, need to syphon. (spaceman)
just use the drain bolt on the tank.
thats what its there for.
Old Nov 2, 2003 | 06:41 AM
liquid51's Avatar
I just used the drain bolt. The car was sitting for over a year and it was 89 oct. anyway. New engine requires 93+.
76 camaro car
Nov 15, 2018 04:33 PM
Hondaisok
Sep 27, 2010 09:30 AM
FO SHO
Apr 11, 2010 01:30 PM
kaoss_11
11
Dec 9, 2004 08:29 PM
Hard2Find
Aug 16, 2004 08:47 PM
