Saab turbo on teg?
Alright, i wasnt sure but one of my freinds down the grapevine said i needed to use a certain manifold if i wanted to use one of the saab t3 turbos i have...I was pretty sure i could use any t3 mani and dp combo and it would work out fine, and do custom piping and oil lines myself...is it true that the saab turbo will only fit w/ a certain mani?..oh another ?...the internal wg on the saab t3, can i just get a dp w/ a 5 bolt flange that blocks off the wg hole and use a external wg? thanks for all the info..peace
i think there are very few saab turbos that need a separate mani, i have a saab tu4rbo as well, and it fit perfect on the drag 3 mani, post a pic of your turbo or one u were thinking of getting, and i will tell yea if it will fit, hope i helped-justin
It's just a standard t-3 flange so any manifold will work. I don't recomend that turbo for A teg though it's a bit small (if it's from a saab 9000)..I believe it's the same one i had which has an ar of .42 ..
I used a drag manifold and it cleared my b16 just fine...
spoolingb20
Oct 3, 2006 05:17 AM
