Need help finding a T3 spacer
When I put my setup together, I had to use a Volvo to t3 flange adapter(ATP Turbo) from the turbo to manifold. My wastegate is mounted on the manifold and the dumptube is recirculated into the downpipe. The Volvo turbo went out on me so I switched to a Garrett T3/T04E, and I no longer needed the adapter for the purpose of aligning the flanges. But because of the recirculated dumptube, I had to keep the adapter on so that the downpipe assembly would fit correctly. But with that adapter there is a very tiny open gap on each side that leaks exhaust gas. So essentially what I need is a 1/4 inch thick t3 flange to make everything go together correctly. Does this make sense and can anyone help me out? TIA!
Is the other side flat like that side, or recessed? Can you take a picture of the opposite side and a pic with a tape measure showing the thickness? Thanks a lot!
