idle up and down, and ruff
Old Apr 17, 2003 | 05:47 PM
sailor's Avatar
Default idle up and down, and ruff
guys,
my car is idling all f'ked up and its runnin ruff. what could this be? i got no CEL .
Old Apr 17, 2003 | 06:27 PM
Chiovnidca's Avatar
Default Re: idle up and down, and ruff (sailor)
Vacumn leak maybe?
Old Apr 17, 2003 | 06:29 PM
poison's Avatar
what motor? check vacuum lines and gaskets.
Old Apr 17, 2003 | 06:34 PM
P1mpSlap's Avatar
Could be your Fast Idle Control Valve or something like that (dunno if that's the acutal name for it).
I know it's on the throttle body and controls airflow and idle.
Look into that.
Old Apr 17, 2003 | 09:17 PM
Westsideboy's Avatar
Default Re: (P1mpSlap)
Check:
- IACV (Intake Air Control Valve)
- FICV (Fast Idle Control Valve)
- Coolant -> Purge air
- Timing
- Idle screw adjustment
Generally, I find that you get bouncy idle if your timing is retarded. Try advancing it a couple of degrees over stock. Gives you better power anyways, and you can still run pump gas without problems.
Old Apr 17, 2003 | 11:41 PM
RangerDan's Avatar
Default Re: (Westsideboy)
If it just started all the sudden it might be you have bad fuel.
Old Apr 18, 2003 | 06:35 AM
sailor's Avatar
anyone of checkin these valves with a voltmeter?
Old Apr 18, 2003 | 06:36 AM
sailor's Avatar
Default Re: (sailor)
anyway* of checkin these valves with a voltmeter?
TearSDMF89dx
Jan 3, 2012 04:31 AM
LOL@hondas
Aug 13, 2010 11:21 AM
troyport
Classic Hondas
May 28, 2009 09:06 AM
dnbruut
Jan 12, 2007 02:38 AM
ATS*Mark
16
Feb 22, 2004 01:00 PM
