best valvetrain setup for turbo?
Old Apr 17, 2003 | 12:26 PM
frogscivic's Avatar
Default best valvetrain setup for turbo?
I did a search but turned up nothing. What is the best valvetrain for a gsr motor with turbo pushing over 400hp? I plan to have the motor daily driven but with occasional track runs.
Thanks JOHN
Old Apr 17, 2003 | 12:32 PM
DaveF's Avatar
Default Re: best valvetrain setup for turbo? (frogscivic)
ferrea valvesprings,retainers, stock size or maybe .5 over size valves with undercut stems . itr cams....thats wht im gonna use...
Old Apr 17, 2003 | 01:07 PM
turbo Si's Avatar
Default Re: best valvetrain setup for turbo? (2.2Lcivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2.2Lcivic &raquo;</TD></TR><TR><TD CLASS="quote">ferrea valvesprings,retainers, stock size or maybe .5 over size valves with undercut stems . itr cams....thats wht im gonna use...</TD></TR></TABLE>
That's exactly what I have had in my car for over 2 years now and to me it's the best. One night , after leaving the club, I just punched it going down the freeway and while trying to race a bike I bounced off my rev limeter in 5th gear twice. My heart stopped, and everything held up great. This was on 11lbs of boost. It's not cheap as Crower, and not to knock Crower, but do a search and see what feedback yo get on there valve train.
Ferrea
Old Apr 17, 2003 | 01:22 PM
94dxt's Avatar
Default Re: best valvetrain setup for turbo? (turbo Si)
sig
Old Apr 17, 2003 | 01:24 PM
T-sohctec's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbo Si &raquo;</TD></TR><TR><TD CLASS="quote">
One night , after leaving the club, I just punched it going down the freeway and while trying to race a bike I bounced off my rev limeter in 5th gear twice. My heart stopped, and everything held up great. This was on 11lbs of boost. </TD></TR></TABLE>
Bouncing off your rev limiter TWICE in 5th ..... the joys of living in the mid west I suppose.
what the **** MPH is that anyway goddamn!
Old Apr 17, 2003 | 02:10 PM
frogscivic's Avatar
From what I have been reading that ferrera was the way to go. Should the valves be dished for the turbo setup? As well are we talking SS valves and if so will they last without having to get new bronze guides?
Old Apr 17, 2003 | 02:17 PM
madmatt's Avatar
Ive always read on here that the GSR cams are better for turbo than the ITR ones? I dont know for sure but thats just what ive read off of HT. Ive also heard great things about ferrea. Good luck.
Old Apr 17, 2003 | 02:25 PM
DaveF's Avatar
Default Re: (madmatt)
as far as itr vs gsr, good question.. i would like to see dyno results with the same car and jsut a simple cam swap with no other variables.
yes. ss valves..id try to run a "flat" valve..i think it would help the combustion chamber to have a "smoother" roof. i am no profesional, thats jsut my opinion.
Old Apr 17, 2003 | 02:31 PM
turbo Si's Avatar
Default Re: best valvetrain setup for turbo? (T-sohctec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by T-sohctec &raquo;</TD></TR><TR><TD CLASS="quote">
what the **** MPH is that anyway goddamn!</TD></TR></TABLE>
They say your speedometer is not accurate past 100mph, mine was past the 140mph mark when I ran out of gear so I would like to assume 145mph?
Old Apr 17, 2003 | 02:32 PM
frogscivic's Avatar
I am going to be running the gsr cams with my setup. Thanks for info appreciate it
Old Apr 17, 2003 | 02:41 PM
DaveF's Avatar
Default Re: (frogscivic)
keep us posted on how it turns out.
Old Apr 17, 2003 | 03:51 PM
frogscivic's Avatar
Default Re: (2.2Lcivic)
Do you know where I could get these at a good price? I will keep yall informed
THANKS JOHN
Old Apr 17, 2003 | 05:47 PM
T3's Avatar
T3
ebay
Old Apr 18, 2003 | 07:43 AM
madmatt's Avatar
Yea theres always ebay and even check the classifieds here cause theres a lot of people goin with skunk2's now. Good luck with the setup.
Old Apr 18, 2003 | 07:51 AM
alpha's Avatar
I went with the following.
Port Flow inner valve springs
ITR outer valve springs
Port Flow titanium retainers
If I were to buy valves they would be .5 oversized Ferrea valves with bronze valve guides. Good luck.
Old Apr 18, 2003 | 08:13 AM
-iLLuZioN-B18C1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by madmatt &raquo;</TD></TR><TR><TD CLASS="quote">Ive always read on here that the GSR cams are better for turbo than the ITR ones? I dont know for sure but thats just what ive read off of HT. Ive also heard great things about ferrea. Good luck. </TD></TR></TABLE>
i believe this is b/c gsr cams have less overlap. correct me if im wrong.
Old Apr 18, 2003 | 09:44 AM
madmatt's Avatar
Yea i think it does have something to do with the gsr cams having less overlap. Thanks. I know ive read it on here. I dont know if the search is up again or what, just look around.
Old Apr 18, 2003 | 01:20 PM
frogscivic's Avatar
Yea I will keep looking on here for some
thanks yall for the info
Old Apr 18, 2003 | 02:30 PM
frogscivic's Avatar
Hey if I get .5 oversized valves will that effect the driveability of the motor or will it just allow the head to flow more?
Old Apr 18, 2003 | 02:40 PM
DaveF's Avatar
wont effect drivability, and head will flow more...i guess it might make a slight differance on low end when crusing, but that is not why you are making your car fast...so i wouldnt worry about it
Old Apr 18, 2003 | 03:49 PM
frogscivic's Avatar
Cool Thanks man
Old Apr 18, 2003 | 04:05 PM
shingles's Avatar
I will be running stock ITR valvetrain on my setup. The only thing I might change is to Ti retainers.
Old Apr 18, 2003 | 04:12 PM
frogscivic's Avatar
Default Re: (shingles)
What kinda of boost u runnin?
ivan93egreppin210
Oct 22, 2012 06:25 AM
prhatch124
Dec 28, 2007 01:46 PM
spoolin turbo s
Jul 7, 2007 06:04 PM
murtnabila
Mar 12, 2006 02:30 PM
