best turbo for 97mm stroker low rpm motor
thinking about boosting my f2b setup. my f23 (97x86) redines at 7k. what size turbo will be best for a street setup? im using the better flowing f22a6 head.
Re: best turbo for 97mm stroker low rpm motor
What kind of power you setting your goal for? Intended use... road racing, drag racing, etc?
The nice thing about these motors is you have displacement to help make up for rpm. They can spool a fairly decent size turbo pretty well.
Its a street setup with track use every now and then. I'm still learning about turbos so I'm not familiar with the different sizes. I run e85 so I will was thinking of boosting at 10-11 compression. I am running a delta 272 cam.
jaxle
18
07-08-2003 08:52 AM
