is the clutch goin bad??
Old Apr 17, 2003 | 12:24 PM
turbocivicef's Avatar
Default is the clutch goin bad??
when i put it in neutral and release the clutch it makes an annoying sound is it the clutch or something else??
Old Apr 18, 2003 | 05:20 AM
JimBlake's Avatar
Default Re: is the clutch goin bad?? (turbocivicef)
Does it make the same noise when you engage the clutch in gear, like when you're starting from a stop? Does it have to be in neutral or does the other noise just cover it up?
Old Apr 18, 2003 | 05:29 AM
gitwidit's Avatar
Default Re: is the clutch goin bad?? (JimBlake)
Does it sound like a bird chirping, go away when you push the clutch back in just a hair? If so, it's your throwout bearing/release bearing.
96gsrdb8
Transmission & Drivetrain
Aug 27, 2018 01:48 PM
DeeJaaY209
14
Sep 15, 2013 10:40 PM
LandeZak
Sep 9, 2013 10:38 PM
Solstic
Jun 13, 2012 11:34 AM
Probot
Apr 18, 2007 07:00 AM
