Brake Grinding Noise
Old Apr 17, 2003 | 09:57 AM
Red Ride's Avatar
Default Brake Grinding Noise
Just got done installing new rear brake calipers, pads, and turned down the rotors on my 94 Sol. Now I am hearing what sounds like a grinding noise from the rear when I apply the brakes.
Is this noise common until the rotors and pads are broken in?
Any ideas
Old Apr 17, 2003 | 09:59 AM
psi420's Avatar
Default Re: Brake Grinding Noise (Red Ride)
Did you re-adjust your parking brake? Sounds like its dragging.
Old Apr 18, 2003 | 06:28 AM
Red Ride's Avatar
I will check it, but like I said, it only makes this rubbing sound when you put the brakes on. Once you let off the brake pedal the sound goes away.
Old Apr 18, 2003 | 08:02 AM
JimBlake's Avatar
Default Re: (Red Ride)
It's normal to make a little rubbing noise until the pads & rotors wear a little. I wouldn't call it 'grinding' though, & it's not very loud. Kind of a 'sshhh' sound. But that's kinda vague since I can't hear it from here.
R.S.
Jan 15, 2007 07:23 PM
wsuozzie
Aug 18, 2006 10:17 AM
93egSIboi
Feb 1, 2005 04:51 PM
Slvr_CRX
Oct 18, 2004 10:48 AM
