ls/vtec Questions....ecu,header, etc....
Old Apr 16, 2003 | 11:58 AM
untitled's Avatar
Default ls/vtec ecu & obd0
To start it off, i have a 91' integra with a b18a.i plan on using a b16a head, and i also want to keep it obd0 to lessen complications. here are my ls/vtec questions:
what ecu to run?
is the exhaust port size different between the 2 heads which would lead me to buy a different header?
what would happen if i ran a pr3 ecu(b16a obd0)? would it be sufficient for the 1.8 displacment?
any other parts i need beside head. oil line kit, ecu?
Modified by 88crx91integra at 3:12 PM 4/16/2003
Old Apr 16, 2003 | 02:20 PM
untitled's Avatar
Default Re: ls/vtec ecu & obd0 (88crx91integra)
cmon.
Old Apr 16, 2003 | 02:30 PM
tommyten's Avatar
dont forget to wire up the vtec signal. I dont think it matters that the ecu is for b16.
Old Apr 16, 2003 | 09:19 PM
untitled's Avatar
Default Re: ls/vtec ecu & obd0 (hatchling)
well wouldnt a b16 ecu have sufficient fuel for 1.6l displacement and the displacment w/lsvtec will be 1.8l. ill have to correct that right. i could probably use a v-afc. what about oil pump do i need a different one for the higher revs? are the rods the same between a vtec b-sereis and non-vtec series? which are better?
Old Apr 16, 2003 | 09:31 PM
Spoonin's Avatar
From what I have seen and read the stock rods are good for a NA application that doesn't push too much more than 200 whp. I was wondering about the ECU and header thing too!
smokey68321
May 26, 2010 09:20 AM
90Rexx
Apr 26, 2009 08:27 PM
allnaturalb16
Jan 14, 2007 04:02 PM
91integraLSVTEC
Dec 25, 2002 09:15 AM
