which supercharger?
Old Jun 26, 2001 | 08:56 PM
Novice's Avatar
New User
Default which supercharger?
which is a better supercharger, the jackson racing version or the vortech version? I am planning on putting a h22a in my '92 accord and was wondering which supercharger is better?
Old Jun 27, 2001 | 10:28 AM
SoloSol's Avatar
Default Re: which supercharger? (Novice)
This is entirely up to you. Check and see the specs on the JRSC and the Vortech. JRSC will give you boost from idle up,the Vortech wil be more like a turbo. Vortech will give more max boost, JRSC has 100K mi warrantee. If it was me I would go JRSC...but, that is only my opinion.
Old Jun 27, 2001 | 08:28 PM
HuGEN's Avatar
Default Re: which supercharger? (SoloSol)
I don't think that Vortec has anything for the H22A. Just my tought.
Old Jun 29, 2001 | 04:04 AM
92sleepR's Avatar
New User
Vortec doesn't have any applications for the H22 (yet) but some things to considder. The JR is a positive displacement blower. Therefore it makes positive pressure from the moment the engine starts turning and its directly proportional to the crank speed so the boost is completely linear. What this means to your backside is lots of nice torque low in the rev range but it doesn't have the *** puckering top end potential of a turbo.
The Vortec on the other hand is a crentrifugal blower, just like a turbo, except that it's driven off the crank. It will suffer from the same low end anemia that many turbos suffer from because it just isn't sized to flow efficiently at lower speeds (it rocks up high though). The main advantage to the vortec design is that it prevents heat buildup in the head and the packaging of the intercooler is really efficient (I think it looks great actually). Its hella expensive though and it really doesn't work as well as a properly designed turbo.
Confused yet?
Compare the dyno graphs of both systems. that says it all.
Now for something REALLY interesting check THIS out. http://www.egarrett.com/g-innovate_eat.html
Mike
b18c inside
Sep 14, 2005 01:30 PM
phantom grey eg
Jan 25, 2005 04:55 PM
2kflamedlude
May 8, 2004 10:47 AM
alsr37
Nov 19, 2002 02:13 PM
112480
Dec 12, 2001 02:47 PM
