Slotted Brembos(stock size) or OEM SI( 99) discs brakes on 92 Hatch??
I already have 4 Brembo's (slotted front) on my VX....should I upgrade for SI disc in front...or stick with Brembo??...
I'm planning to lapping a lot this summer....wich should be the best choice...??
durability/performances??
tanx
tanx
Wait wait, now I'm confused... maybe it's just because I got out of a crazy class and my brain is fried BUT. Are you saying that you are swapping the knuckles/calipers/rotors and whatnot from a 99 SI?
yep exactly... OEM SI(99) upgrade disc swap....(front only)....on a 92 hatch
and can I have a picture of what I need for the upgrade(si) by the way...(diagram)...??
Si brake upgrade, do it now!!!
I had those dinky VX brakes too, and swapped in SiRII brakes up front and it makes a noticeable difference. Screw that slotted rotor crap, you can put them on the Si brakes later if you want.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lowexr »</TD></TR><TR><TD CLASS="quote">yep exactly... OEM SI(99) upgrade disc swap....(front only)....on a 92 hatch
Ok, in that case you should DEFINATELY do that! not only are will you have larger rotors, but you will also have larger calipers, SO much better than simply putting slotted on your car. And since your car weighs less than an SI you shouldn't really have too much brake fade.
Scott
Scott
Zenosuke
May 20, 2011 05:23 PM
unsungfate
Oct 27, 2008 01:15 PM
ST4TUS
Jul 27, 2007 09:24 PM
lowexr
Apr 16, 2003 08:33 AM
