92 si brakes
92 si brakes
i need new brakes for my car and i was wondering if anyone has used pwerslot rotors and how the like them, also since i already have 4 wheel disc brakes do you think there is a NEED TO UPGRADE TO INTEGRA rotors and calipers
Re: 92 si brakes (dose)
The integra brakes are the same size as yours Si. If you want to upgrade your brake go here for more info. http://www.fastbrakes.com
I have the powerslot on the front but they go with the fastbrakes big brake kit. There's a big improvement between the stock CX and the big brake kit.
Former Moderator
Re: 92 si brakes (CivicNewbie)
Posted by CivicNewbie:
Absolutely <FONT COLOR="red">INCORRECT</FONT>.
The 1994-up Integra rotors are the same size as the 1994-1995 Si hatch, but the 1992-1993 Si hatch has smaller discs. The Integra calipers are still better than any 1992-1995 Civic Si calipers anyways.
I ran the Integra fronts on my 1992 Si and it made a difference. Try this:
Get the front spindles from the 1994-up Integra GS-R. Buy a 1991 Civic EX 4-door non-ABS master cylinder. Get the rotors of your choice - I prefer the PowerSlots made by Brembo.
Add it all up and you'll stop sitloads better.
***Let me add that the rear discs are all the same on the 1992-1995 Si and all 1994-up Integras except for the Type R***
Re: 92 si brakes (B18C5-EH2)
The 92-93 and 94-94 Si hatch have the same part number for the front rotors, which is they're the same size.
92 Si: http://www.hondaautomotiveparts.com/...EXC.+SI+ABS%29
95 Si: http://www.hondaautomotiveparts.com/...EXC.+SI+ABS%29
Former Moderator
Let me correct you and myself partially:
The 1992-1993 Civic rotors are in fact smaller than the 1994-up GS-R rotors. 1994-1995 ABS was an option on the Si hatch, so perhaps if you look up those rotors they will be the different part number and THOSE would be the same size as the 1994-up GS-R rotors.
I OWN a 1992 Si hatch still and I'll post pics of the SMALLER THAN GS-R rotors since you're trying to prove your point.
Either their site is simply wrong, or it's only the 1994-1995 Si with ABS rotor that's the same size as the 1994-up GS-R.
You're right this time, only the 1994-1995 Si with ABS rotor that's the same size as the 1994-up GS-R. I just dig up my old Si rotors (I do own a 92 Si a while ago), they're smaller than the GSR.
Former Moderator
Here you go CivicNewbie:
http://www.hondaautomotiveparts.com/...2795+SI+ABS%29
THAT is the same size as the 1994-up Integra. That's the diagram for the 1995 Civic Si hatch with ABS.
Look man I'm just trying to keep you from leading our friend down the wrong path.
Here is the FACT:
The 1992 Civic Si front rotors are NOT the same size as the 1994-up Integra GS-R rotor.
Here is the FACT:
Former Moderator
thanks for all the replys answered my question but now i got another ,,b18c5-eh2 said get a master cylinder off a 91 4 door ,why wouldnt i get it for a integra rs?
EthanolSTi
03-06-2014 03:23 AM
boost and bass
07-15-2009 02:56 PM
delslowhonda
05-17-2006 01:35 AM
lowexr
04-16-2003 06:27 PM
