ECU reset problems...
Old Jun 26, 2001 | 08:36 PM
raene's Avatar
Default ECU reset problems...
How long should you unplug your battery to reset your ECU? And after reset, is it necessary to let your car warm up completely before driving it?
The reason I ask is, I did a valve adjustment, f*cked up a gasket, fixed that problem, and then tried to drive the car cold before letting it warm up. It just kept trying to stall everytime you'd take your foot off the pedal, and after a minute of driving it would just stall if you took your foot off the gas, period.
I parked it, unplugged the battery, waited 5 minutes, plugged it back in, let it idle for 5 minutes (until it smoothed out and stopped wandering) and the problem went away... does this sound like an ECU problem or a cold-idle problem?
[Modified by raeneshadow, 9:37 PM 6/26/2001]
Old Jun 27, 2001 | 10:49 PM
raene's Avatar
Default Re: ECU reset problems... (owkone)
You're supposed to reset when fully warmed huh? Shoot, I never knew that! Thanks man!
But wait... wouldn't that cause some funny problems when you're just finishing a valve adjustment on an ice-cold engine? You can't exactly start it up fully warm... and the ECU should have been reset.
iCollectStraws
Feb 12, 2010 09:42 AM
moecivic
Dec 19, 2004 11:28 AM
4inspeed
Jan 9, 2004 01:21 PM
PolySquared
Nov 29, 2003 06:09 PM
Extent
Dec 29, 2002 02:22 PM
