Cam seals
Old Apr 15, 2003 | 09:25 PM
Sivicfied's Avatar
Default Cam seals
Are cam seals hard to change? Mine seem to be leaking oil.
Old Apr 15, 2003 | 10:09 PM
JDMH22HATCH's Avatar
Default Re: Cam seals (Sivicfied)
Easy cheezy. Takes about 15 minutes.
Old Apr 15, 2003 | 10:19 PM
Wilson_'s Avatar
Default Re: Cam seals (JDMH22HATCH)
your probley thinking cam plug on the dist. side cam seals are on the timeing belt side. they take a little bit longer
Old Apr 16, 2003 | 09:39 AM
Sivicfied's Avatar
Default Re: Cam seals (Silverstone00Si)
Sorry, I got the nomenclature wrong but that is what I want to replcade the round black plugs near the "dis" is leaking. How much should cost to get replaced on average?
Old Apr 17, 2003 | 04:23 PM
Wilson_'s Avatar
do it your self the plug is 10-15 bucks if not less while your doing it get a valve cover gasket 10 bucks and honda bond HT 5-7bucks
take valve cover off on the dist side you will see the journal that holds the cam plug take the 4 bolts off and wiggle around to get it off take out the cam plug and clean journal
next take the honda bond and put it all the way around the plug(not alot) and put it in put the cap back on the journal and tighten the bolts down then put the valve cover gasket on then your done
have fun and then take a break then have a
hope that helps
Old Apr 17, 2003 | 05:39 PM
Civic2Fast's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Silverstone00Si &raquo;</TD></TR><TR><TD CLASS="quote">do it your self the plug is 10-15 bucks if not less while your doing it get a valve cover gasket 10 bucks and honda bond HT 5-7bucks
hope that helps
Yeah what he said
Old Apr 18, 2003 | 10:32 AM
Sivicfied's Avatar
Thanks exactly what I was looking for.
Old Apr 18, 2003 | 10:58 AM
rodrez.'s Avatar
Why even change it? It's doesn't look that bad
Old Apr 18, 2003 | 11:02 AM
Project SSAP1's Avatar
Default Re: Cam seals (rodrez)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rodrez &raquo;</TD></TR><TR><TD CLASS="quote">Why even change it? It's doesn't look that bad
that isnt ****!!! this is better
Old Apr 18, 2003 | 11:16 AM
rodrez.'s Avatar
Default Re: Cam seals (Project H22DC4)
Ohhhhh man
Old Apr 18, 2003 | 11:29 AM
Civichatch972's Avatar
yeah I had a problem wit my swap it was leaking and thought it was the head gasket.
But replaced cam plug and valve cover gasket and solved the problem
Took me about 20 min.
Old Apr 25, 2003 | 10:32 AM
Sivicfied's Avatar
Default Re: Cam seals (Civichatch972)
Mine isn't leaking that badly. However, should also replace the bolt orings for the valve cover? And what about the plugs do they have gaskets or rings too?
speed84
Sep 6, 2007 06:33 PM
SpoonFedHatch
Mar 22, 2006 06:25 PM
worktech
Feb 8, 2006 01:04 PM
DC2NING
Jun 23, 2004 02:38 PM
blackdude
Mar 17, 2004 08:55 AM
