weird tranny issues...
Having some really weird tranny issues. When I engage the clutch I`m hearing this high pitch sound almost like a dentist`s drill. This effects the idle and the car wants to stall. Anytime the clutch is engaged it`s putting load on the motor.
Last weekend we pulled the trans (thanks ryan and ryan) to inspect. The area around the starter looks as if the clutch might have been rubbing against it so we shaved it back a bit more and tried a new clutch (thought we might have had an ls clutch which is a different part number). Bolted everything back up and the sound and problem is still there. This is a new motor, but the trans is a used ITR Unit. I put 500 miles on the new motor before all of this started happening.
I`m beginning to think it could be the trans. Any ideas?
Ryan
Ryan
Thats an odd problem, and yes if you wanted attention this coming month you should have added expo to the post topic
I hope someone will chime in and help ya
yOnKiNaToR
Apr 23, 2006 03:15 PM
PariahBoardshop
Sep 19, 2004 04:32 PM
colesd16
Jun 28, 2004 08:22 PM
